I have a body lift to install which should eliminate any guard rub.
I dont want to go super high to try and avoid the truck having any ideas of rolling over, BUT i want more flex and to soften the ride a bit, a bit hard with leaves maybe??
Im in two minds weather i go spring over and maybe take a leave or two out to soften it, but would this make the old girl too high? OR extended shackles and again take a leave or two out? So not as high as a spring over but still gain some flex ect.
If some one has some experience with these old girls in setting the suspension up that works, would be great
Also swaybars, take them off or better to keep them? It will be still used on the road.
