3 inch lift wd21
For all Nissan related topics
mr terrano
3 inch lift wd21
Post by mr terrano »
iv seen 3 inch springs what would i need todo to front to match this height in rear please
ChurchurDan
Re: 3 inch lift wd21
Post by ChurchurDan »
Aftermarket upper control arms, shocks, modified steering and torsion bars wound up.
derk
Post by derk »
if you stuck 3" lift springs in the front there wouldn't be any down travel left so it would be pretty hard to keep both front wheels on the ground at the same time :D
Crash bandicoot
Post by Crash bandicoot »
Not worth doing the 3 inch lift even though calmini do a 3 inch lift kit as you wont have any strength in the steering.
use the search function here and look for terrano build threads so you can see what is involved even before getting to the actual lift.
Return to “Nissan”
