I'm trying to get a 1984 HJ60 back on the road and I need a front sway bar as the one on mine has been removed. I need the lot, including links and bushes.
anything out there?
Front sway bar for a 60 series landcruiser
Re: Front sway bar for a 60 series landcruiser
Maybe I will have a look in the morning for you.
Thanks, I need to keep the cert guy happy
I found one for a 70, I think it is the same.
- stovanovich
You don't need a sway bar for a wof but you need one for Cert? Seems a little strange to me
Te Rino
"Hubs In, Caps Off"
"Hubs In, Caps Off"
I'm going to use a 60 series chassis as a base for something else and I want to keep the thing standard. I'll post some pics when things have progressed a bit
- mudlva
diogenese wrote:I'm going to use a 60 series chassis as a base for something else and I want to keep the thing standard. I'll post some pics when things have progressed a bit
just be awere that a lot of axle articulation comes from the twist it the chassis, if you cage it up you will stiffen the chassis and end result is it will lift a wheel quite easy
keen on seeing what you are building
It's not going to be caged, hopefully a slightly more interesting tow car.
