Toyota surf 1990 v8 sas For sale
Selling or wanted vehicles.
jonossiksilvia
Post by jonossiksilvia »
Time to sell it - going a different way now.
http://www.trademe.co.nz/Browse/Listing ... 08&ed=true
Here is the build on here for it viewtopic.php?f=18&t=27747
1990 Toyota hilux surf 284398kms
1uz v8 1992 engine 94000kms following done before being fitted:
Cambelt, water pump, idlers, coils, spark plugs, new starter, ecu water sensor, alternator rebuilt, power steering pump rebuilt, ecu rebuilt
1uz auto flushed and filter changed, surf transfer bolted on back
2.5” twin exhaust exit out each side. 4 mufflers – nice sound to it
Walbro external fuel pump
Silvia alloy rad, falcon xr6 fans and shroud mounted to back controlled using a proper controller with switch for water crossings, air separation system
Big trans cooler, power steering cooler, remote engine oil filter
3” snorkel stainless steel. Surf air box with 3” inlet and outlet
Twin batteries
Prado solid beam axle, fully rebuilt, all bearings and seals done, new wheel studs and nuts, all steering joints have been replaced
4.88 ratio diffs new from trail gear in states, bearings done in both, open front lock right rear
Rebuilt front callipers, new disks, pads, hoses all round, new rear cylinders. (needs new master cylinder – long pedal travel)
Rebuilt steering box
40mm body lift and steering shaft extension
3” suspension lift, cobra springs, raw shocks, rear panhard drop bracket (front end a little stiff, rear perfect. Think shocks too stiff)
35” maxxis creepy crawlers and 15x8 steel rims x5. 4 have 80% tread left so still as new and spare never used
60mm water temp gauge
Boot window relay kit. Window works perfect and bypasses the factory sensors
Jvc cd usb head unit. 6.5” fusion splits fronts, Panasonic rears
Front, rear and side bar work including tow bar
Rubber flares
Certed,
wof till October under 15kms since last wof
rego will be updated on sale 3 months - currently on hold
Cost to build well over $20000
Doesnt come with winch or uhf radio
Edit updated link
Last edited by jonossiksilvia on Wed Jul 22, 2015 8:16 pm, edited 3 times in total.
jonossiksilvia
Re: Toyota surf 1990 v8 sas For sale
bump price reduced
May swap for a kzn185
