adding turbo to a td27
nissandatsun
Post by nissandatsun »
hi all I am in the process of taking the turbo setup off one td27 terrano to install it on a d21 td27 navara ute ,there is no plugs on the drivers side to power the egr vaves,just wondering if i need that butterfly in the pipe from the turbo to the intake manifold as i wont have any vacuum to operate it???? :?
if its not broken your not trying hard enough
Crash bandicoot
Re: adding turbo to a td27
Post by Crash bandicoot »
Lose anything related to the EGR in a bin somewhere and forget about it.
nissandatsun
but what about the butterfly between the turbo and intake can i just pull that out?
Crash bandicoot
nissandatsun wrote:but what about the butterfly between the turbo and intake can i just pull that out?
yep, pull it out thread the holes in the alloy housing where it pivots and stick some bolts in there with loctite, blanking plates for the manifolds and bob's your aunties dogs cousin twice removed
nissandatsun
awsome cheers
nissandatsun
also do you know what sort of fuel economy i should expect after adding the turbo (runnin 5 speen manual gbox)?? cheers
Crash bandicoot
nissandatsun wrote:also do you know what sort of fuel economy i should expect after adding the turbo (runnin 5 speen manual gbox)?? cheers
depends how you drive it.
nivaman
Post by nivaman »
The 5 speen manual gbox should make some difference.
