still got a x on the roof bar under and above front windscreen 2 b pillars and few braces here and here will post pics feel free to let me no if heading off track ,last thing to do then can entrer challenges well hopefully
imsohi wrote:No b pillars shouldnt be needed you do get a bit of flex between the front and back, or make some removable ones only problem with them is the tend to pick up sticks/trees and fire them into your rear doors. not sure on NI rules but in the south rear stays need to be straight. otherwise looking good.
.monstr wrote:the only problem I see with your cage is the back stays really need to be straight as far as im aware
tuff lux wrote:After Easters winch challenge started sorting a few issues we had![]()
Ass end we have dropped it down as much as possible and putting bumps in
Have taken the body lift out... So bit of mucking around with cage
Good bye Front leafs doing a 3 link in front
Notch the chassis
