Hydraulic steering help / advice
Team Tonka
Post by Team Tonka »
Trying to do the maths and knowing what sort of output I'm gonna get from the standard Toyota power steering pump would be helpful. So anybody got any idea what sort of pressure and the flow rate? Is it a fixed displacement pump or a variable displacement one. Thinking it will be the latter?
Also has anyone ever used the standard ps pump for hydraulic steering and if so what was the outcome.
Thanks in advance, Andy.
May the force be with you.
ONOescudo
Re: Hydraulic steering help / advice
Post by ONOescudo »
Im no expert, but in general terms an automotive power steering pump and like a Toyota Camry power rack can be used in conjunction with a orbital steering control valve from a fork lift, tractor or boat as long as the orbital unit has a thinner spacer in the body. Rather than a thicker spacer as this would use to much hydraulic oil. This is the advice that I'm working with. I am also going down the hydro steering road.
NJV6
Post by NJV6 »
No idea on flow but there is a chap down here that runs both front and rear steer from a Camry pump, the one that has two outlets, one for steering and the other for the factory hydraulic fan.
dvk-kp
Post by dvk-kp »
Don't know if it would be any good but some nissan pumps have 2 outlets as well... Hicas for rear steering. Skyline, cefiro, laurel etc.
Return to “Tool Shed”
