help
For all Suzuki related topics
4x4man
help
Post by 4x4man »
hello
my mate has a suzuki escudo and is wanting help on what to do because every time he goes through a puddle fast and water gets up around the engine, the engine only just goes and has no revs to drive and takes a couple of minutes before it gets going again.
can any one help me on what to do ??
Smurf
Re: help
Post by Smurf »
Start by sealing up the distributor and plug leads.
Or tell him to slow down.
stovanovich
Re: help
Post by stovanovich »
As above ^ slowing down stops so much splash.
Te Rino
"Hubs In, Caps Off"
4x4man
Re: help
Post by 4x4man »
its not that fast he goes even just when going through a mud hole.
how do u seal up those parts ???
Smurf
Re: help
Post by Smurf »
remove the cap and apply sealant to the edge with the O-ring. make sure the O-ring is in good condition. Seal the leads to the cap also.
A spray of CRC or similar on the electrics before a trip out can help too
4x4man
Re: help
Post by 4x4man »
okay thanks
so nothing to hard required :):):
moonhopper
Re: help
Post by moonhopper »
I have had the same issues with all Suzuki's ive owned, best solution I found was a product from CRC
its a spray rubber compound but you can remove it if required. spray over top of distributer and top of spark plug caps
as they don't always seal that well.
never had a problem again.
4x4man
Re: help
Post by 4x4man »
okay thanks
so u dont even need to pull the distributor apart ???
dvk-kp
Re: help
Post by dvk-kp »
Plasti dip is also good for it... Spray on and let it set then it's got a rubber coating.
4x4man
Re: help
Post by 4x4man »
okay where can u buy plastic dip from ??
dvk-kp
Re: help
Post by dvk-kp »
Repco, supercheap, trademe etc. it's not hard to find.
4x4man
Re: help
Post by 4x4man »
oh yea is that the one where you have to buy a special color of it ?/
dvk-kp
Re: help
Post by dvk-kp »
Na it's just like spray paint but is a rubberised coating.
http://m.supercheapauto.co.nz/Product/P ... 11g/353850
Ant
Re: help
Post by Ant »
CRC soft seal is the stuff you want. Just spray it everywhere around the plugs and distributed will form a rubber seal around everything
92 LWB Safari TD42
4x4man
Re: help
Post by 4x4man »
okay thanks heaps for the help
he should be pleased now :)
4x4man
Re: help
Post by 4x4man »
could it also be anything to do with the air intake ??
4x4man
Re: help
Post by 4x4man »
since the air intake is above the front wheel could that have anything to do with it ???
Smurf
Re: help
Post by Smurf »
possibly, take the top off the air filter and look for water.
you can remove te piping that goes from the filter through the guard. It means the motor isn't getting cold air but it moves the intake point a bit. still not ideal though.
He would have to hit water pretty hard to get it all the way through the intake pipe.
4x4man
Re: help
Post by 4x4man »
okay then i would more say it is the distributor then
Smurf
Re: help
Post by Smurf »
seal the lead on the coil too
4x4man
Re: help
Post by 4x4man »
okay do i just use that same spray on stuff ??
Smurf
Re: help
Post by Smurf »
soft seal or silicone it.
May pay to check any other pipe/hoses on the intake that may not be sealed completely that may let water in.
Return to “Suzuki”
