minimizing my engine loom
spanky
Post by spanky »
because of great american wiring i would like to get rid of as much of my wiring as possible,97 cherokee sport. idealy iwant a power switch ,ign,and start button.not sure if its possible because of the illogical way jeep do their wiring,anyone tried this. cheers vaughan
Mattman
Re: minimizing my engine loom
Post by Mattman »
Are you having a problem with your stock wiring?
If not done properly cutting the factory loom can cause issues.
derk
Post by derk »
watch out for all the anti theft security shit if those things have it mate :D
Crash bandicoot
Post by Crash bandicoot »
used to do it to race cars all the time basically dismantle the ignition switch making the power feed the common between all switches/momentary push button, then wiring switches and push button start to the outputs as per usual arrangment...after all the ignition switch is basically just a key operated multi switch.
Return to “Jeep”
