Any chance someone's got some measurements for the above bushes - r180a
Trying to source some eccentric bushes to drop the front diff
WD21 front diff mount bushes
- stovanovich
Re: WD21 front diff mount bushes
BlakeNZ wrote:import them?
https://ruggedrocksoffroad.com/front-di ... -4157.html
Only problem there is the excessive shipping cost, I've been looking to this myself so I can swap my r180 for an r200
Te Rino
"Hubs In, Caps Off"
"Hubs In, Caps Off"
- Crash bandicoot
i just measured the clearances between the drive shaft flanges and the torsion rods then unbolted the two mounts and cut out about 20mm and welded them back together.
Cheers mate, couldnt find the link for some dyslexic reason. Bit the bullet and forked out $160 they're on their way now
