Y60 starter problems
For all Nissan related topics
turbosaf
Post by turbosaf »
I am at wits end my my safari. Have replaced starter motor about 6 times now. Any advise or any modifications i can do to help the situation??
skidmark
Re: Y60 starter problems
Post by skidmark »
What fails on them? Is it the same thing each time?
mudtroll
Post by mudtroll »
Are you sure your replacing them with the correct voltage starter motor?
Mehrts
Post by Mehrts »
What exactly is, or isn't happening with it?
Is it slow to crank, just clicks, does nothing at all?
Toyhatsu Bitsalux
turbosaf
Post by turbosaf »
Well the relay will just clicks and starter does nothing. Its like everytime i go 4wdriving. I understand they dont like mud and water but the last one only lastex one outing
turbosaf
Post by turbosaf »
mudtroll wrote:Are you sure your replacing them with the correct voltage starter motor?
Yes definately all 24v.
Mehrts
Post by Mehrts »
Is it the starter relay, or the solenoid within the starter assembly that is clicking? Have you checked all wiring connections are reasonably clean (at the battery etc).
I had what I thought was starter issues earlier on in the year, go to start, and the solenoid would just click with no starter rotation. I pulled out the starter and gave it a once-over, but it all looked really clean inside, so I put it back together and started looking around.
What it turned out to be was a bad connection of the large starter cable on the battery. Gave it a clean up and everything was sweet as again.
Toyhatsu Bitsalux
Crash bandicoot
Post by Crash bandicoot »
check the earth to the engine block from the battery.
Madaz
Post by Madaz »
Have you tried a jumper cable straight from positive on the battery to the starter?
Ialso had a faulty starter relay, must have broken down inside, would still click, but every now and then was a no go
churchill
Post by churchill »
Sounds electrical too me too.
-Make sure that the solenoid is seeing 24v when you turn the key (the small wire on the solenoid). If not you'll need to find where the voltage drop is and fix it or put a relay in the starter circuit.
-Make sure all the thick cables to the starter have clean terminals at any point they join.
-Make sure your battery is in good condition.
I suspect the first one is the issue.
turbosaf
Post by turbosaf »
Cool sounds like some things for me to try. I will get back to you
Return to “Nissan”
