Hi
I have fitted a couple of the ARB switches. And they are getting HOT when switched on. It is a the bulb in the switch.
I have done a search here and can not find anything. I have also done a search else where and find it is a common issue.
What I would like to know is what have people here done about it?
Thanks Henry
ARB Switches Hot
Re: ARB Switches Hot
Mine get hot too ... just how it is ... its just the bulb heating up.
will only be the lamps if they are switching relays. if you are switching a direct load through them make sure they are rated to the load. can see how hot they are getting with a laser thermometer (readily available quite cheaply now) and i wouldnt be to worried about anything under 60degC (too hot to hold a finger on)
It's just the lamp as said earlier. If it's really an issue, then you could look at replacing the incandescent bulb with an LED alternative. I'm actually a little surprised that ARB haven't used LEDs in the switches already. When I first installed the switches, I noticed how warm they get, but didn't worry about it much.
Toyhatsu Bitsalux
ARB don't make them they are carling switches.
Id don't like the ARB graphics are too hard to read at night ..ive got better designed cover.
https://www.otrattw.net/
