surf rear diff
surf rear diff
hi was wondering if anyone knows if it is possible to put a rear diff of same ratio in my ln60 beam axle surf out of a ln130 2lte. my axle code is g252 and later surf donor is g254. I know this means the later one is 4 pinion rather than my 2 pinion. any help would be great cheers
- Checkerhead
Re: surf rear diff
Yes, you can.
Sounds like you already know, but "g" means 8 inch, 25 is the ratio and you know about the 2 pinion/4 pinion.
So yes, they are basically the same thing and can be swapped.
Re: surf rear diff
yeah the diff head will bolt right in. IMHO. Can you do the swap yourself?
Re: surf rear diff
