Electronics
Pat D
Electronics
Post by Pat D »
Is anything electronics the best to deal with and are they reasonable in pricing.info please.
Im a Tumor
Re: Electronics
Post by Im a Tumor »
might need to be a bit more specific...
mudsurfv6
Re: Electronics
Post by mudsurfv6 »
Im a Tumor wrote:might need to be a bit more specific...
http://www.anythingelectronic.co.nz/aenz/index.php
Andrew 0272226292.
Re: Electronics
Yeah, had them fix my 1KZ ECU had no problems and they give you a quote first, they can fix other auto electronics as well
kbushnz
Re: Electronics
Post by kbushnz »
I have sent a few jobs to them.... Never had an issue... As said can strip and quote first before doing the job to see if its worth it... Naturally there is a fee for strip and quote.... Give them a call....
Pat D
Re: Electronics
Post by Pat D »
Thanks for the replies.It does seem that they have a good reputation.I have a starting problem just now,it will start then switch it off and it won't start again until some flu key thing happens and it starts again .Any ideas please.Pat
tweake
Re: Electronics
Post by tweake »
Pat D wrote:Thanks for the replies.It does seem that they have a good reputation.I have a starting problem just now,it will start then switch it off and it won't start again until some flu key thing happens and it starts again .Any ideas please.Pat
need details of vehicle, engine and the fault. its not always the ecu.
a mates car had that and i traced it down to the ecu relay, after auto sparky spent thousands replacing everything else!
Pat D
Re: Electronics
Post by Pat D »
It's a KZJ78 auto with the 1 KZTE.any help appreciated
Smurf
Re: Electronics
Post by Smurf »
Where are you? Someone local may be able to loan you their ECU to test in your Prado to eliminate/prove the issue?
Re: Electronics
pm kbushnz and see if he can lend you his to test it
Pat D
Re: Electronics
Post by Pat D »
Have just discovered a diesel leak at threat of the pump
tweake
Re: Electronics
Post by tweake »
Pat D wrote:It's a KZJ78 auto with the 1 KZTE.any help appreciated
need to know what the fault is in detail.
if its leaking fuel then its also sucking in air which can make it hard to start.
kbushnz
Re: Electronics
Post by kbushnz »
Jerry wrote:pm kbushnz and see if he can lend you his to test it
No longer have an ECU..... mine went to Canada.... And now I dont run one... But happy to assist as required...
Smurf
Re: Electronics
Post by Smurf »
Pat D wrote:Have just discovered a diesel leak at threat of the pump
About $150 and easy to replace on a 1KZ
Gyxx
Re: Electronics
Post by Gyxx »
Jerry wrote:Yeah, had them fix my 1KZ ECU had no problems
Ditto....
I had the 1KZ ECU from my KZJ fixed by Anything Electronic and I'm another satisfied customer.
Pat D
Re: Electronics
Post by Pat D »
I'm crippled up a bit at the moment so took the Prado to an auto electrician and the prob is the ecu so he is sending it to anything electronics so with a bit of luck should be home next week.this is a very good forum to be part of.thanks folks.
Pat D
Re: Electronics
Post by Pat D »
I took my Prado to Barry auto electricians in Kumeu.He tested it found the Ecu was faulty,sent it to Anything Electronics in Nelson and after very few days it is back in the Prado fully rebuilt and performing superblyMy thanks and recommendations to both Steve at Barry auto electricians and Anything Electronics.Pat Delich
Return to “Toyota”
