Electronics
Electronics
Is anything electronics the best to deal with and are they reasonable in pricing.info please.
- Im a Tumor
- Bush Crasher
Re: Electronics
might need to be a bit more specific...
Re: Electronics
Im a Tumor wrote:might need to be a bit more specific...
http://www.anythingelectronic.co.nz/aenz/index.php
Andrew 0272226292.
Andrew 0272226292.
Re: Electronics
Yeah, had them fix my 1KZ ECU had no problems and they give you a quote first, they can fix other auto electronics as well
Re: Electronics
I have sent a few jobs to them.... Never had an issue... As said can strip and quote first before doing the job to see if its worth it... Naturally there is a fee for strip and quote.... Give them a call....
Re: Electronics
Thanks for the replies.It does seem that they have a good reputation.I have a starting problem just now,it will start then switch it off and it won't start again until some flu key thing happens and it starts again .Any ideas please.Pat
Re: Electronics
Pat D wrote:Thanks for the replies.It does seem that they have a good reputation.I have a starting problem just now,it will start then switch it off and it won't start again until some flu key thing happens and it starts again .Any ideas please.Pat
need details of vehicle, engine and the fault. its not always the ecu.
a mates car had that and i traced it down to the ecu relay, after auto sparky spent thousands replacing everything else!
Re: Electronics
It's a KZJ78 auto with the 1 KZTE.any help appreciated
Re: Electronics
Where are you? Someone local may be able to loan you their ECU to test in your Prado to eliminate/prove the issue?
Re: Electronics
pm kbushnz and see if he can lend you his to test it
Re: Electronics
Have just discovered a diesel leak at threat of the pump
Re: Electronics
Pat D wrote:It's a KZJ78 auto with the 1 KZTE.any help appreciated
need to know what the fault is in detail.
if its leaking fuel then its also sucking in air which can make it hard to start.
Re: Electronics
Jerry wrote:pm kbushnz and see if he can lend you his to test it
No longer have an ECU..... mine went to Canada.... And now I dont run one... But happy to assist as required...
Re: Electronics
Pat D wrote:Have just discovered a diesel leak at threat of the pump
About $150 and easy to replace on a 1KZ
Re: Electronics
Jerry wrote:Yeah, had them fix my 1KZ ECU had no problems
Ditto....
I had the 1KZ ECU from my KZJ fixed by Anything Electronic and I'm another satisfied customer.
Re: Electronics
I'm crippled up a bit at the moment so took the Prado to an auto electrician and the prob is the ecu so he is sending it to anything electronics so with a bit of luck should be home next week.this is a very good forum to be part of.thanks folks.
Re: Electronics
I took my Prado to Barry auto electricians in Kumeu.He tested it found the Ecu was faulty,sent it to Anything Electronics in Nelson and after very few days it is back in the Prado fully rebuilt and performing superblyMy thanks and recommendations to both Steve at Barry auto electricians and Anything Electronics.Pat Delich
