96 v6 surf
mudsurfv6
96 v6 surf
Post by mudsurfv6 »
might as well start this thread.
96 vzn185 surf, standard, for now.
will be a slow build, as time and money allows.
plan is (no doubt will change)...
sas prado diff with hilux axles surf hubs, prado trailing arms. lokka locker.
ln130 transfer case. (kzn130 in there instead)
rear electric prado locker in rear.(in a 90 series prado diff, so got disk brakes)
change to 4.3 diff heads, from 4.1
35x16 goodride mud legend for road and simex et off.
2 inch body lift.
hopefully lift fuel tank 2 inches.
front 2 inch lifted prado springs/shocks.(wouldn't fit, so factory struts for now, they lifted it 4")
rear standard 80 series springs/shocks.(had to get 4" lifted springs to keep same as front, 2" lifted 80 shocks)
TRD supercharger. URD kit.
snorkel (just a cheap one until the exo gets done).
cross over steering. 70 series? 130 steering box.(80 series box better fit)
take air bags out.
HID head lights, factory aren't that great. (lvvta say can't just change bulbs, got to change whole lamp. :evil: )
cert.
save up $.
some bar work, got a 12000lb runva to mount in back for forwards and reverse pulling. will put a 9500lb on front.
twin alternators. two batteries. (front bar done, with 12000 runva in it)
save up heaps more $.
probably a year or two away.
cut cab down behind back seats.?
simple exo cage incorporating snorkel for body protection. winch challenge specs.? might need a 6 point internal cage by the sounds of it?
small rear deck hopefully end up like a ute flat deck ish, for pigs deer, or for carrying dogs, whatever...
rear disk brake conversion. change whole diff or use what? (done)
cert.
at some stage
lights.
pull all carpets out.
transmission cooler.(done)
bead locks.(got stauns waiting)
change front seats and add 5 point belts.
air tank and compressors for tyres.
be more....
Andrew 0272226292.
Sheepy
Re: 96 v6 surf
Post by Sheepy »
Cool to see a 185 getting the treatment.
Crash bandicoot
Re: 96 v6 surf
Post by Crash bandicoot »
you may find it is easier to get a double cab shell with just the rear door's then bolt all you panels/front doors lights n grill etc to it, as you may have the same issue i have coming up.....it is the back seat seatbelt tensioners sit behind the C pillar.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
Crash bandicoot wrote: back seat seatbelt tensioners sit behind the C pillar.
hadn't looked at that. might end up making it a bob tailed well side.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
a bit been done. running boards off. snorkel on. uhf and am radios in. 265 75 16 federal couragia mts on for now, keeps it wofable.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
had a few spare minutes, fitted the trans cooler behind front bumper. just got to find time to change hoses over from bottom of radiator.
will get changed one day when front bar gets done.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
slow progress. 2" body lift done.
Andrew 0272226292.
dvk-kp
Re: 96 v6 surf
Post by dvk-kp »
Coming along nicely Andrew. Going to be a beast when it's done. 8)
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
dvk-kp wrote:Coming along nicely Andrew. Going to be a beast when it's done.
can't wait till its done :D
nearly got all the parts. looks like going to use a prado transfer now instead of 130 surf so will have pto.
Andrew 0272226292.
dvk-kp
Re: 96 v6 surf
Post by dvk-kp »
Good news. Pto would be handy... God winch for the win haha :D
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
dvk-kp wrote:God winch for the win haha
would be nice but not gonna have much room now, once its double cabbed gotta fit spare wheel, big ass truck battery & two electric winches under flat deck.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
you got me thinking last night, might be worth looking into. have to put the spare on top of deck though.
Andrew 0272226292.
dvk-kp
Re: 96 v6 surf
Post by dvk-kp »
After watching the videos on the net of them I reckon it would be worth the effort. Gees they are impressive!
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
ok, transfer case changed to a kzn130 one. wiring not done yet so haven't got 4wd or speedo. get to it one day. had to change to a VZN130 rear driveshaft because 130 transfer is shorter. also the crossmember under the transfer case got moved back to suit the mount.
picked up a 90/95 series prado rear diff so will have rear disk brakes. will fit the electric locker into it sometime, a bit of welding & cutting to come.
started on SAS.
before
before
before
before
a bit of grinding
a bit of grinding
no suspension
no suspension
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
most gone
most gone
plasma
plasma
cleaned off
cleaned off
sitting there
sitting there
factory struts, a bit of an issue.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
still got to change hubs to surf ones.
didn't realise chassis too wide to use prado springs & shocks, so ended up using the factory struts. bit too hard. its sitting right at bottom of suspension.
see viewtopic.php?f=13&t=44769
also sump isn't going to work, need a rear sump.
see viewtopic.php?f=22&t=44758
Andrew 0272226292.
vvilly
Re: 96 v6 surf
Post by vvilly »
If you gonna use the surf front struts. The early sheep shagga ones have the same mounts but give 3 inches of lift
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
vvilly wrote:If you gonna use the surf front struts. The early sheep shagga ones have the same mounts but give 3 inches of lift
ok, is that if they are mounted on top of diff? the surf ones have given about 5" of lift, but are too hard & its sitting with the springs completely extended. would the shagger ones be softer?
Andrew 0272226292.
vvilly
Re: 96 v6 surf
Post by vvilly »
I cant answer that but alot of the 4 runner dudes in the states use them to give them 3 inches of lift.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
will have to look into it.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
going to just stick with the factory struts for now and see where it sits once we have added weight to the front. winch bar. winch. supercharger. etc. have ordered 4" lift rear springs to sit it nearer level, and going to use 2" lifted 80 series shocks which are 4" longer than surf ones.
bit more done.
70 series steering
70 series steering
80 series box
80 series box
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
electric locker into 90 series prado diff.
ready
ready
in
in
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
on the trailer back home to get a bit done over xmas.
steering all done, need to get made a power steering hose between pump & 80 series box.
35" mud legends on 80 series rims, will see how they go as road wheels.
waiting for sump pan, then can swap that.
when rear springs turn up then can put prado diff in place.
surf hubs to swap onto it.
thanks for the work Cole, good job.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
steering hose made & fitted. getting pretty busy in that small space.
ps cooler fitted, not overly long but hopefully better than nothing.
so now running again, need to fit another windscreen washer tank though, not enough room below drivers side headlight anymore.
Andrew 0272226292.
mudlva
Re: 96 v6 surf
Post by mudlva »
As the power steering bloke said to me. You can not have to much cooling. More so when running big flat tyres
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
mudlva wrote: You can not have to much cooling.
yep, especially after supercharger is fitted.
going to put vents towards both back corners of bonnet, also two 10" electric fans in the bulge in bonnet above supercharger to suck as much heat out as possible when going slow off road. when on road & fans off they will still vent around blades.
tomorrows job swap sump pan & pick up etc to rear sump from a T100. hopefully reasonably simple.... :? :roll:
Andrew 0272226292.
lax2wlg
Re: 96 v6 surf
Post by lax2wlg »
Cool. Interesting use of factory struts. For the spring height issue, have you considered cutting the springs? Ie removing one coil?
How much stroke do the factory shocks have?
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
lax2wlg wrote:For the spring height issue, have you considered cutting the springs? Ie removing one coil?
have thought of that, but going to wait until we have added winch bar & winch in a couple of weeks, and then hopefully the supercharger. see what that weight does to the front.
lax2wlg wrote:How much stroke do the factory shocks have?
haven't measured them. we were planning on using prado 2" lifted coils & shocks but chassis too wide. the factory struts were the only other things we had sitting there so just put them back in instead.
will see how they go and change them later if doesn't work out.
Andrew 0272226292.
Madaz
Re: 96 v6 surf
Post by Madaz »
I wouldnt stress to much about the heat from the supercharger, unless you were having overheating issues before hand.
When I supercharged mine it made no difference at all to how hot it runs offroad.
As long as you have a good radiator I doubt you would have any issues
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
Madaz wrote:I wouldnt stress to much about the heat from the supercharger, unless you were having overheating issues before hand.
it has got hot a couple of times but 1st was jammed thermostat, and 2nd was viscous fan stopped working. had to drill 2 holes through hub & bolt solid because we were in middle of nowhere, have replaced hub but hasn't been drivable since.
otherwise it has always been fine, even when towing.
just thought better safe than sorry.
Andrew 0272226292.
