Question i got asked today..
revolving around r200 lsd coversion to the longer D22 front axles.
you have to disassemble the inner tripod joint and swap the 5 bolt flange cv onto your ale and cv
remove the inner tripod joint rubber boot on the d22 and then tap the cup down onto the axle, a seal will pop off exposing the tripod,
clean the grease off remove the circlip, then tap the tripod off the axle shaft.
part numbers 2.3.5.6.7 and 15 bottom left of image 5 bolt inner
wth the 5 bolt cv, remove the rubber boot /slide it down the axle, clean away the grease and you should see a large inner circlip that holds the race inside the cup, slide it out and remove the smaller circlip from the other side/end of the axle... tap bearing race off the axle and reassemble them onto the d22 axle.
IF the race wont budge from the cup of the 5 bolt cv cup, remove the cover over the end and do it the same way the tripod joint is done.
