cheers brett
toyota 1jz in hilux
toyota 1jz in hilux
hey guys have just had engine conversion done in my 85 d-cab from 2.4 deisel to 2.5 1jz petrol motor
out of a crown or creseda have one problem the car the motor came out of got crushed and the "map senor" was in it so we have motor in and runing and computer all going just missing one little plug that plugs into computer and vacume so the engine knws what its doing
and with out this one little plug th motor runs realy rich and sounds like junk i have tryed puting a map sensor from a caldina on and it worked and ran alot better but i need to find one from a "1jz" engine does any1 have or know of any1 or any wreckers that would have anything? i have tried all of the wreckers in chch sounds like theres not many 1jz's around
anyone have any contacts that could source a part like this
cheers brett
cheers brett
Give toyota a go too, sometimes their random-number parts price generator has a hiccup & an item will actually be a sensible price. It's rare but it does happen so it's always worth calling.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
I rang Toyota when I found the sensor missing and asked for a price........................................ $600 - $700 with an 8 week lead time
Also asked for a cross reference to see if they used the same sensor on any other engines but no luck
Toymotor spares in Wordsworth street has a box of Map sensors, none for the 1ZJ, which you could try, maybe find one that will get you by until a real one turns up.
How did the new exhaust turn out ?
Insky wrote:yea i mite try yours wjw![]()
exhaust good they did a tidy job its quite loud though hopefully not to loud for cert
Txt 021190441 or call 963 3586... will be out and about this weekend, but should be able to meet up at some point, should only take 10 mins...
Who knew Prados could fly?
