am looking for a short auto and transfercase and probably tourqe converter to mount to a V6 commy motor
anyone got one lying around
anyone done this previously??
text or ring Warren
0274913440
wtd short auto and trans
Re: wtd short auto and trans
How short?
I had a lux transfer on the back of a nissan RWD Auto and that was shorter than a zuk box and divorced case. You will find most RWD autos have quiet a long tail section that can be cut off. doing that took about 230mm out of the nissan auto. It always amazes me how much shaft there is in a factory 4wd box set up.
- mudlva
Mount a fwd auto to the motor snd weld the diff up to become a transfur case
Its what the trails boys were doing and worked well.
They were turning 35s quite easily
Only down side was no high range
Cheers guys
Think abut that if I bolted a rwd auto and used my transfercase divorced could work ..........
now to find time to look at it then do it ............................ and pay for it
