Hey all, iv recently perchased an 88 lwb safari. Shes an absolute beauty apart from the roof which is absolutely rooted as is the case with many. I was looking at replacing it with a good one then saw some guys have converted the body into utes so that got me thinking again. Has anyone had theirs converted to a ute? Who did the work and what did it cost?
Either way the roof has to go just thought maybe I could do it all at the same time.
Thanks
Ute conversion for safari
- mudlva
Re: Ute conversion for safari
The only cert requirement is fir the cabin rear wall.
Cut behind the front seat seltbelt mounts and it will be a easy job for cert etc
Excluding tray and the cab roof rust but panel beater 2 to 4 days at a guess plus painting .
Budget $3-5k
Tray anybodies guess. How flash do you want it?
Rust is never quoted but has he will have the roof lining off etc he will have a better idea then.
I say do it they do look good
Budget $3-5k
Youre right they do look good. I would make the flat deck myself being an engineer, Im pretty hopeless when it comes to body work although I could manage it but it wouldnt look as good as id want it and its probably be easier to pay someone. I might go see a panel beater after work and see what they say about it then
ChurchurDan
One of the panel shops in Chch do Landcruiser conversions for around the 7k mark for a drive in drive out job.
any idea of the company name? im in ashburton so its just up the roadChurchurDan wrote:One of the panel shops in Chch do Landcruiser conversions for around the 7k mark for a drive in drive out job.
ChurchurDan
Burkes metal works
