I need to fully weld the box to the housing in the notch that I have cut out in the housing
I also use an old diff head that I cut down and can fit a true'ing bar through it so I can see how much I have moved it when I pre tension and how much I have to correct the diff to line it up again.... all that said I personally think they can stand a fair bit of miss alignment, the reason I go to the level I do is if your charging for service you do it properly and I can say to the client it is true and mean it lolMadaz wrote:Ive always done the shave with a diffhead bolted in and made the filler plate a exact fit, havnt had to many issues sofar
