how do i get this out?
mudsurfv6
Post by mudsurfv6 »
changing surf sump pan from front sump to rear sump to clear prado diff.
viewtopic.php?f=18&t=43405
need to get the plug out that I need to put a new union in for new dipstick but its in there really tight. :evil:
I've had vice grips on it and its turned a bit. put a cut off screwdriver up inside it and hammered but doesn't want to budge. don't say heat because I've no way of doing it, apart from a lighter. :roll:
that's the new one.
thought about just drilling a hole up inside one already in there but then why would they supply a new one. the dipstick tube has to seal inside top.
Andrew 0272226292.
UBZ
Re: how do i get this out?
Post by UBZ »
Looks like a press fit and that you almost have it out to the point where it tapers off.
Go and grab yourself a can of freeze spray , cant remember exactly what its called .
Freeze and shrink the plug , opposite of heating the block around it
Mehrts
Post by Mehrts »
CRC Penetr8 freeze off spray is what I've used in the past with great results for dealing with seized components!
Toyhatsu Bitsalux
mudsurfv6
Post by mudsurfv6 »
cool thanks for that guys, i'll have a look tomorrow.
Andrew 0272226292.
lax2wlg
Post by lax2wlg »
Mate out of it that you managed to find parts from a T100!!
U probably know this but they were a cool vehicle, but USA only. It was theyre bridge gap while they designed the 1st gen tundra for the U.S. market.
Loving your build thread by the way. keep it up!
diogenese
Post by diogenese »
You have the sump off so bash it out with a drift from underneath. It's pressed in not screwed in.
johnny262
Post by johnny262 »
I've got a propane torch here in pht if u need it. Pm me
mudsurfv6
Post by mudsurfv6 »
diogenese wrote:You have the sump off so bash it out with a drift from underneath
I've tried with a cut off screwdriver so that its flat on the end not pointed. its not a very big hole in middle. maybe I'm not hitting hard enough. whats a drift?
johnny262 wrote:I've got a propane torch here in pht if u need it. Pm me
have got some of that freeze spray today and have sprayed it on. i'll try that first, if doesn't work I might get hold of you. I'm 20 mins towards alfredton.
Andrew 0272226292.
churchill
Post by churchill »
Get a punch with the diameter 0.1mm to 0.5mm smaller the small end of that part and smack it out from underneath upwards. It's just pressed in lightly but might be a little corroded in. You'll have to take the splash place off first.
diogenese
Post by diogenese »
It's just something that goes between the thing you are trying to hit and your hammer, like your sawn off screwdriver ; )
If your screwdriver is a close fit like Churchill said hit it harder!
mudsurfv6
Post by mudsurfv6 »
diogenese wrote:hit it harder!
will try that tomorrow after work.
Andrew 0272226292.
mudsurfv6
Post by mudsurfv6 »
half a can of crc penetr8 freeze spray and a heap of harder hitting and its out. now I have to figure out how to get the other one in, its straight below the engine mount. might have to hold engine up elsewhere and take mount off. even then not much room below manifold. :evil: :evil:
Andrew 0272226292.
diogenese
Post by diogenese »
Keep the new bit in your freezer till you need it, the smaller it is the easier it will fit.
mudsurfv6
Post by mudsurfv6 »
diogenese wrote:Keep the new bit in your freezer till you need it, the smaller it is the easier it will fit.
good advice, will put in there now. :)
Andrew 0272226292.
Mehrts
Post by Mehrts »
Yep good advice, some aircraft rivets are cooled in liquid nitrogen before use, so as they expand when they warm up, they form a tighter fit in the hole.
Toyhatsu Bitsalux
mudsurfv6
Post by mudsurfv6 »
new fitting in. was way easier than getting old one out. there is a bolt for mount in the perfect spot to lever off, started with a tyre iron then moved onto a 1/2 meter wrecking bar which had the perfect flat spot on end to sit on bolt & bend just in the right spot to sit on the union and with my shoulder under the trailing arm it just pulled straight in. the freezing must have helped and hopefully now its warmed up it will be really tight.
Andrew 0272226292.
Return to “Tool Shed”
