Bench Seat, Saf front?
MihiT
Post by MihiT »
Just wondering if anyone has done this? Or if it was ever a stock option, I don't think it was...
does anyone know which safs came out with an umbrella handbrake (I see the knockout is there beside the steering column)?
but asides from that I can't see much that would need moving.
TIA.
1989 LWB 5-Seat TD42
mudlva
Re: Bench Seat, Saf front?
Post by mudlva »
I know the older mk/q?? Utes came out with a two seat passangers seat .
And if i remember correctly i think the qu ute ez aussy had a bench seat in it.
I had the two seater under the house. Will have a looksee when under there next if interested
MihiT
Post by MihiT »
mudlva wrote:I know the older mk/q?? Utes came out with a two seat passangers seat .
Do please.
I'll have to check out the mounting and whatnot but definitely keen to see if it will fit.
mudlva
Post by mudlva »
Guess what i found
mudlva
Post by mudlva »
Found a set of 70 series cruiser seats as well
MihiT
Post by MihiT »
mudlva wrote:Guess what i found
What are they worth to you?
Obviously you've seen them mounted, how does that work out with the tunnel, it's quite high in the gq, but i dont know about the mk/q, presumably there's another seat rail needed on the drivers side of the seat?
mudlva
Post by mudlva »
The l.c. seat were reappolistered and retrofitted into a mid wheel ex bh74. They owe me $400.
the mq/k seat i used in a fj60. Bought off t.m. for $50
Best to head across and have a looksee and make ya decission from there
MihiT
Post by MihiT »
mudlva wrote:The l.c. seat were reappolistered and retrofitted into a mid wheel ex bh74. They owe me $400.
It would be the nissen one... My other option is to get handy with the ply and foam, which I'm slowly convincing myself isn't a bad idea.
Where is "across"?
mudlva
Post by mudlva »
In in papakura south of auckland
monstr
Post by monstr »
the knock out your referring to is prob the rear sway bar disconnect that some came out with ,it was located passenger side of steering
MihiT
Post by MihiT »
monstr wrote:the knock out your referring to is prob the rear sway bar disconnect that some came out with ,it was located passenger side of steering
That is where it is...presumably that was cable actuated?
Either way it wouldn't take much to convert to an umbrella handbrake.
