Terrano Gearbox swap
For all Nissan related topics
hamboy
Post by hamboy »
Hey guys, I'm looking at swapping out the FS5W71C in my D21 for a FS5R30A from a R50. Will the older transfer case bolt on to the later box?
lax2wlg
Re: Terrano Gearbox swap
Post by lax2wlg »
hamboy wrote:Hey guys, I'm looking at swapping out the FS5W71C in my D21 for a FS5R30A from a R50. Will the older transfer case bolt on to the later box?
Dont quote me but I dont think the 71c transfer will work. The R30A uses the transfer with much bigger transfer chain. Dont quote me but I think a transfer case from a V6 manual box will fit (same R30 transmission, just bigger ratios). Theyre all the same TX10 transfer though. Confusing.
You'll love the big box, its such a strong unit for the size/weight.
Crash bandicoot
Post by Crash bandicoot »
Transfer from a 97 onwards mistral would work with r50, but if its the r3m-r model it will also have a viscous centre coupling as well.
lax2wlg
Post by lax2wlg »
Crash bandicoot wrote:Transfer from a 97 onwards mistral would work with r50, but if its the r3m-r model it will also have a viscous centre coupling as well.
Whats r50? Are you referring to the Patrol gearbox or the R50 model Pathfinder?
Neither are relevant to this thread :wink:
Crash bandicoot
So he wants to put a r50 box in a d21 lax. That how I've read it.
Crash bandicoot
And two answer your question no. And r3m-r definitely not.
Mattman
Post by Mattman »
I have a complete manual conversion for an R50. Everything included plus box has been rebuilt.
hamboy
Post by hamboy »
Mattman wrote:I have a complete manual conversion for an R50. Everything included plus box has been rebuilt.
For a TD27?
lax2wlg
Post by lax2wlg »
Ask KBJJ, hes had lots of experience playing with these gear/transfer combos.
ChurchurDan
Post by ChurchurDan »
For a TD27?
It will be as no QD32eti terranos came out manual. The box will fit a QD but you will need a different flywheel.
Return to “Nissan”
