winch breather
mudsurfv6
winch breather
Post by mudsurfv6 »
just wondering where people have added a breather to their winch? pictures? how to do it?
I've got a runva ewx12000 if it makes any difference.
Andrew 0272226292.
kbushnz
Re: winch breather
Post by kbushnz »
When I ran an electric winch I fully sealed the motor and tapped in a hose fitting in the end cap.... It never got water in it when I had it....
As for the gear box end.... Just made sure it had a coating of grease....(not packed full)
(Warn Xd9000i) You can see the hose fitting in the brush cover towards the left of the pic.
Lchundy
Re: winch breather
Post by Lchundy »
This my one
I also sealed it all up with good silicon
Had spare connections and line in diff breather kit so put it on winch
mudsurfv6
Re: winch breather
Post by mudsurfv6 »
Lchundy wrote:This my one
kbushnz wrote:You can see the hose fitting in the brush cover
thanks for that, I have a brass fitting spare that I can use.
Andrew 0272226292.
mudsurfv6
Re: winch breather
Post by mudsurfv6 »
this brass fitting I have, its 5/16 hose by 1/8 BSP. standard fitting.
I have googled what size drill bit & what tap I need to use to fit it but now more confused.
can someone please tell me in English what size drill bit and tap to use?
Andrew 0272226292.
kbushnz
Re: winch breather
Post by kbushnz »
First you need to confirm it is a BSP thread...or BSPT (T = tapered)
The drill size for tapping a 1/8th BSP or BSPT is 8.8mm so says the cart below.
http://www.tap-die.com/contents/en-uk/d ... Sizes.html
Whatever you have you need to rock into an engineering supplier and get a tap to match... Take in the fitting and they will ID it for you..
mudsurfv6
Re: winch breather
Post by mudsurfv6 »
kbushnz wrote:First you need to confirm it is a BSP thread...or BSPT (T = tapered)
packet says BSP.
kbushnz wrote:Take in the fitting and they will ID it for you..
its the same size and thread as the breather holes in surf/hilux/prado diffs if that helps.
Andrew 0272226292.
mudsurfv6
Re: winch breather
Post by mudsurfv6 »
panic over folks. :)
the cap on the end is just soft crap so I drilled a 9mm hole, put some pressure on the nut part with a smaller ring spanner and just threaded the fitting into the hole. :roll: didn't take too much pushing, but should be tight enough to not let water in, hopefully.
fitting is as low as I can get it & the hose is clear so if any water does get in i'll see it in the hose.
sorted. :)
Andrew 0272226292.
Return to “Tool Shed”
