Hi all, I'm wanting to know which model mechanical pump would be the best to go forr and or what engine they come off. And how hard are they to rebuild as Im hoping to score one of a wreck along with the injectors.
Also want to know how much $ roughly should it cost for a turbo shop to change my side mount IC to a top mount.
R50 td27eti pump swap
Re: R50 td27eti pump swap
You want a D21 terrano turbo pump but if you have an auto you will have trouble getting it to work properly as an auto again. Why change the intercooler? they work fine where they are and if you want a bigger one they have heaps of room for a front mount. Top mounts also heat soak if moving slowly unless you have a fan on them.
