Toyota 3L ( 2.8dsl ) Flywheel wanted.
SMOKEY
Post by SMOKEY »
Hi all, It's time I replaced my Dual mass flywheel and clutch on my 2LTE Toyota. I have priced all the parts and then thought some one may have a flywheel that they are useing as a door stop or paper weight and are wanting to cash it in. The Toyota guru's may be able to tell me, are the solid 2.4 and 2.8 flywheels the same ? . As the flywheels are heavy CHCH , or Canterbury areas only please, the other thing is I am pulling it down tomorrow night.
If I can borrow a 3L flywheel to use as a sample I can make one. :idea: :idea:
SHORT ARMS --- LONG POCKETS,
FITZY.
worzel
Post by worzel »
Hi Fitzy
some are and some are not depends on year you want a 8 bolt one thats the 3l one
If i got one at work you are welcome to borrow it to see if you can make one
give me a ring tommorow and will have a look for you
Kev
Return to “Toyota”
