96 v6 surf
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Dec 27, 2015 5:03 pm
old pan off
look how clogged the old filter is
and how clean the new one is
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Fri Jan 01, 2016 5:54 pm
new pan on.
new dipstick.
Mattman
Re: 96 v6 surf
Postby Mattman » Sat Jan 02, 2016 7:09 pm
Nice work
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Jan 03, 2016 12:49 pm
rear driveshaft hoop done. 50x5mm flat & 4x 10mm 8.8 bolts so hopefully pass cert.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Jan 17, 2016 6:48 pm
front bar made.
thanks baden.
next job bar off, paint it. next weekend swap rear diff for the prado diff & 4" lifted springs. bleed brakes. then fit (hopefully can figure it out) the TRD supercharger etc.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Fri Jan 22, 2016 9:04 pm
1st coat of paint tonight.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sat Jan 23, 2016 11:47 am
surf rear diff out.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Jan 24, 2016 5:39 pm
and prado diff in.
put power onto locker to unlock it, jacked a wheel up and can spin one.
brakes bled, enough to get it to town anyway.
tonight's jobs are put another coat of paint onto front bar, & trim shroud because fan blades are hitting it, new viscous hub is a bit longer than the old one.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Jan 31, 2016 9:46 pm
fitting the supercharger.
before
during
now just need the done photo.
still some vac hoses to hook up, and one wire left on the computer and hopefully will be going. :mrgreen: 8)
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sat Mar 05, 2016 11:18 am
supercharger on, hoses hooked up. can't try it cos it won't start.
130 windscreen washer in, 185 one was where the steering box is now.
bar on, lights fitted apart from indicators. winch in but rope not on yet. bash plate will go on when I have made some 90 degree bends for the trans cooler hoses. still need to swap hubs to surf ones, will be a bit wider then to match rear.
Mehrts
Re: 96 v6 surf
Postby Mehrts » Sat Mar 05, 2016 1:44 pm
That's a pretty neat fit with the supercharger with regards to manifolds etc, nice and compact
Toyhatsu Bitsalux
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sat Mar 05, 2016 2:31 pm
Mehrts wrote:That's a pretty neat fit with the supercharger with regards to manifolds etc, nice and compact
TRD, so just bolts into place. vacuum hoses are different lengths but otherwise straight swap.
OffroaderGuy
Re: 96 v6 surf
Postby OffroaderGuy » Wed Mar 09, 2016 2:42 pm
good progress. impressive work
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Fri Jun 03, 2016 7:27 pm
OffroaderGuy wrote:good progress. impressive work
Mattman wrote:Nice work
cheers.
front hubs are done, front wheels are in about 10mm each side compared to rear, so will get a fresh bite on side of rut.
photos to come....
is now running, ended up being a plug unplugged behind dash :oops: :roll: but still vacuum to sort.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Aug 28, 2016 7:41 pm
been slow with moving house and job.
but got something done.
removed intake silencers, americans reckon a gain of 5-7RWHP so must do something, :) and supposed to sound gruntier too. :D
hopefully let the supercharger breath a little bit easier. 8)
removed these.
next job wire supercharger computer back in.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sat Sep 24, 2016 5:00 pm
Sc computer wired :lol: :roll: in, haven't started it yet.
Auto sparkies close eyes now....
And a bit tidier.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sat Oct 15, 2016 5:54 pm
back nearly stripped out ready for cutting. roof lining to unclip and windows to take out.
seats can stay there until back is in right place then take them out.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Mon Oct 24, 2016 8:00 pm
no going back now. :)
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Nov 06, 2016 4:49 pm
Now just got to measure where it's going to fit and cut it neater. seat belts dictate where back goes.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Dec 04, 2016 6:00 pm
A bit done, partly bird pood in. A few gaps where not cut flush, will cut guards and pull gaps closed, won't be visible behind deck anyway.
Think I might buy a regulator and disposable bottle for the panel work.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Dec 11, 2016 10:56 am
Big achievement for the weekend, made an extension for handbrake cable holder thingy :lol:
Worked half of Saturday dagging last of ewes ready for shearing, and only got an hour in shed.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Mon Jan 09, 2017 5:56 pm
Got sick of spot welding panel steel so started on rear cross member.
catalystracing
Re: 96 v6 surf
Postby catalystracing » Tue Jan 10, 2017 11:10 am
Good looking project Andrew, did the steering wheel fit like you hoped ?
Was good to meet you and the family Saturday, hope the trip home went well.
Paul.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Tue Jan 10, 2017 12:06 pm
catalystracing wrote:Good looking project Andrew, did the steering wheel fit like you hoped ?Was good to meet you and the family Saturday, hope the trip home went well.Paul.
haven't tried the steering wheel yet, hopefully will fit.
good to meet you, and put a face to the name. got home about 6.
sirLachlan
Re: 96 v6 surf
Postby sirLachlan » Tue Jan 10, 2017 8:47 pm
I'm pretty sure that drive shaft hoop will require another piece in the middle to encapsulate the drive shaft more . If it broke and traveled the length of the u bend it would have no trouble whipping all that off
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Tue Jan 10, 2017 8:59 pm
sirLachlan wrote:I'm pretty sure that drive shaft hoop will require another piece in the middle to encapsulate the drive shaft more .
I have wondered if that would be the case, so will end up making another piece to bolt in centre closer to the driveshaft. another job added to the list.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Feb 05, 2017 4:02 pm
All closed in, just some bog to smooth off and paint. :D quite pleased considering it's the first time i've used a mig.
BlakeNZ
Re: 96 v6 surf
Postby BlakeNZ » Sun Feb 05, 2017 5:33 pm
awesome, been waiting for this stage. Any side on photos?
Can i assume you are retaining the rear window function of being able to be wound down, electrically?
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Feb 05, 2017 6:01 pm
BlakeNZ wrote:Can i assume you are retaining the rear window function of being able to be wound down, electrically?
that was the plan, but would only go down to top of arches, which is about half way. also I had to cut the bottom off the runners the window slides in to fit around arches. so window now doesn't move.
plus the rear radiator will either be behind window on the left, or horizontal on roof straight above rear window so be safer if window didn't open anyway.
BlakeNZ wrote:Any side on photos?
have tried to take a sideish on photo but not much room in shed, i'll add off my phone.
mudsurfv6
Re: 96 v6 surf
Postby mudsurfv6 » Sun Feb 05, 2017 6:04 pm
