i modified the prado intake manifold to get rid of the throttle body and egr system and smoothed out some of the sharp edges in the standard manifold.
intake manifold and intercooler together.
had to modify the throttle since the throttle body is going. so made up a fly by wire throttle by the brake master cyc.also have the prado intake pipe to the turbo,(rocket cover and breather pipes)still to be installed.
will be interesting to see the difference's in egt/power(using my g-tech meter it averaged 100hp at the moment).i am planning on just running the intercooler for a few runs to see egt diff then adjust fuel up to get more power
