300tdi into early Landy 90
werc1
Post by werc1 »
Hi team - I have an early Land Rover 90 with a Nissan LD28 swap into it. I'm toying with the idea of swapping in a 300tdi.
My understanding is the 300tdi will bolt to the lt77 and only requires the original motor mounts fitted to the chassis to work. I can source the motor and all the bits that go with it, but am having trouble finding a shop either capable or that has availability to do so.
Any recommendations here in Auckland? Thanks in advance
quattro
Re: 300tdi into early Landy 90
Post by quattro »
If its an early suffix lt77 they are as weak as shit. Get a later r380. To make it easy you can buy a shoft bellhousing r380 from ashcrofts
Discovery 4bd1t project
