This is happening. Gathering information/parts to swap td27 for the qd32
from what I can gather the block is identical - meaning I should be able to use same engine mounts
-manidolds in and out bolt over
-my td27t inj pump will bolt into qd32t
-am I better to source a non turbo qd32 or a factory turbo one
-im keeping my auto trans for now. i need to source a different flex plate ? (6 or 7 bolt crank maybe)
-is vac pump on qd32 gear driven off block or just off back of alt like td27?
-sumps may be a problem?
From what i can trawl out of old posts on here Im quessing need a QD32T long block from an auto r50 terrano , possibly with starter and vac pump. Everthing else I have
I know kiwipete did this a while back, but sold it
Any input much appreciate
[/url]
