Want to buy 80 series rear upper control arm
Flash2004
Post by Flash2004 »
A stock unit please, can fit new bushes of course, I've broken mine somehow. Anyone had any success welding them? Rod Broke off right at the top bush. Left side if theyre different, Thanks
sig
Jeep Jeep
Re: Want to buy 80 series rear upper control arm
Post by sig »
i may have a couple .will have a look when im next at my lockup
Clint
Post by Clint »
If yours is an older 80 I think the upper arms on 1993+ 80 series are stronger, Edit: no they aren't :oops: the lower ones are definitely bigger on the newer models. They should weld back together no problem though.
Clint
UZJ71 Landcruiser
KTM 640
Flash2004
Post by Flash2004 »
Thanks Clint, I've dropped the bits to an engineer's this morning and he's confident he can get a good weld on it without burning the bush even. Mine's a '94 but its an Aussie model with the barn doors and part time 4wd, FW hubs etc. so may be different to the average VX we get here. The top arms are 400mm centre to centre and the bottoms much longer. Hopefully the weld will take and no more problems. cheers, and thanks, Gordon
Flash2004
Post by Flash2004 »
sig wrote:i may have a couple .will have a look when im next at my lockup
Thanks Sig, please see my update below. If the weld doesn't work, I be back, cheers and thanks, Gordon
sig
Jeep Jeep
Post by sig »
sweet as
Clint
Post by Clint »
Edit: I was wrong about the later upper arms being beefier - they are the same. The lower arms on the 93+ 80 series definitely are stronger though. Good luck with the fix.
Clint
UZJ71 Landcruiser
KTM 640
