Anyone have an LD28 Flywheel, the closer to southland the better,
Pulled the engine out of my Kingswood and it only has a flywheel and clutch for a 2 litre in it which explains why it slipped every chance it got, especially with a turbo hanging off the motor the clutch shop was surprised it lasted this long
thanks Ollie
Ld28 Flywheel WTB
- Crash bandicoot
Re: Ld28 Flywheel WTB
So you be wanting a l28ET flywheel then.
and if it takes your fancy bore it out 3mm and use Honda xl 500 dirt bike pistons and rods from the L24 engine.
tha't'll give ya 3 litres and drop the compression so ya can crank the shit outa that garrett turbo...that's if its a factory LD28-T
Hey, can either of you guys tell me what Turb the LD28 should have??
It looks like a T3 or T4 flange in the mani, but it's only a baby diesel so it needs the right turb otherwise it will be laggy and work in the wrong part of the rev range.
We have half the Turb
- Crash bandicoot
You'll be wanting a a/r 48 from a latevmodel blacktop td27/qd32 ( the garret ones)DieselBoy wrote:Hey, can either of you guys tell me what Turb the LD28 should have??
We have half the Turb![]()
my LD28T had a air research t04E on it. (Unsure if this was factory or not) But it was a lot smaller than a normal (petrol) T04E.
need a ld28 flywheel which holds a nine inch clutch as mine currently has a flywheel from a Datsun 180b which is the same size but holds and 8 inch clutch causing it to slip
also I have a blown spare turbo of my ld28 if your interested
cheers ollie
cheers ollie
Still after one i got a a spare in the shed.
ld28 an l28 are different weight and offset/thickness.
i run l28 on back of ld to mq box.
yes still looking does it take the 9 inch clutch
Will measure tomorrow.
