Disposable Welding Gas Bottles - CHCH
Anyone know of a Christchurch supplier of these:
http://www.trademe.co.nz/business-farmi ... 997168.htm
Have looked at bottle rental, but its just not cost effective for me.
Thx
Thx
Who knew Prados could fly?
Re: Disposable Welding Gas Bottles - CHCH
The Toolshed shops sell 2 litre disposable cylinders similar to that for $90. Not sure on pressure/capacity though.
You'd only have to go through about 3 a year before it was better value to rent a bottle though. Have you priced up Air Liquide? when I got my TIG a couple of years back I was amazed how much cheaper than BOC they were.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Sent the wife to Air Liquide last week, smallest they do is a D size, $156.49 to start then $24.12 per month or $197.80 annually. I know its not much, but its another monthly outgoing, disposables are easier to justify as I can cost it into each of the projects.Clint wrote:The Toolshed shops sell 2 litre disposable cylinders similar to that for $90. Not sure on pressure/capacity though.
Clint
Or I could buy a bottle for $499 and do a bottle swap.
Not sure on the economics now but I when I did the numbers filling an owned bottle was much more $$$ than a renter. I worked out that if I was using more than 1 F size Argon bottle per year (which I do usually) renting was the cheaper option. Now I'm not emptying Argon onto various bits of Landcruiser in quite the same volumes as the last couple of years
I probably should look at an owned bottle again as I think bottles are getting cheaper plus they are doing swaps locally rather than wait a week for a fill.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
I'd go owner bottle every time now. I had basically paid for a bottle renting for a couple years with a handful of fills or so.
Not a whole lot dearer to fill and my recent bottle has over 9 years left on the test.
Good if you're like me and might use 2 bottles worth in a couple weeks then sit idle for months.
Cost me $400 last year to buy an F sized bottle filled with Ar-CO2
2 day or so turn around on fills depending on gas - In Hamilton.
Eziswap has a better network now too but they worked out dearer to buy into and swap. I was also then tied to the only distributor in our area whose shop I didn't like. I think there's a chch distributor for them.
Those little throw aways would be ok for small stuff but wouldn't take many before the price got up on ya. Body/sheet work with mig or any processes with back purging can eat a lotta gas.
I spent $80 getting an old fire extinguisher tested and valved at the local cylinder tester. now its $35 per fill. I only do 2 to 3 fills a year.
Do you specifically want argon or could you settle for just co2?
I
I
I did look at that as CO2 is sooo much cheaper, but for what I want to do, both google and the people I know who do this stuff every day have said to go AR/CO24x4 wrote:Do you specifically want argon or could you settle for just co2?
I
I was told I could only do that with CO2callum007 wrote:I spent $80 getting an old fire extinguisher tested and valved at the local cylinder tester. now its $35 per fill. I only do 2 to 3 fills a year.
phatlaurel
- Driver/Navigator
I can sell you a used d size cylinder that you can use for argon or argon/co2 mix, pretty sure I got one lying around depending what your keen to pay for it
it costs 140 to fill
Bugger, bought a disposible and regulator on Wednesday... will ping you when I run out..phatlaurel wrote:I can sell you a used d size cylinder that you can use for argon or argon/co2 mix, pretty sure I got one lying around depending what your keen to pay for itit costs 140 to fill
phatlaurel
- Driver/Navigator
that's kool I think I got a couple in the shed
Have just run out, Still got some bottles? Am after a D Size for Argon/Co2.phatlaurel wrote:that's kool I think I got a couple in the shed
Bill
phatlaurel
- Driver/Navigator
ill take a look in the shed tonight
Hey guys who fills owner bottles in CHCH
De-Ranged wrote:Hey guys who fills owner bottles in CHCH
Air Liquide behind Mitre10 in Hornby. Not sure exactly as I sent the wife
7 Canterbury Street Hornby Christchurch 8042
Lol and if it was like my ex the price depended on the top she wore when she went in
Thats it.... lower cut = lower priceDe-Ranged wrote:Lol and if it was like my ex the price depended on the top she wore when she went in
She got 70% off retail @ steel n tube
phatlaurel
- Driver/Navigator
low cut top may get you discount at Tanktest in woolston too
