1990 terrano - any problems? or general thougts?
- dannyboy4949
- Driver/Navigator
G'day fellas,
Looking at a 1990 Nissan terrano 3000 petrol around 97000km for around $4500. Any thoughts, common problems, or things to look for would be greatly appreciated. Being my first buy into the 4wd world it would be good to hear some views
Thanks for your time
Dan
Dan
- dannyboy4949
- Driver/Navigator
- deer_hunter
- Driver/Navigator
- dannyboy4949
- Driver/Navigator
terrano
a guy got one in the club been out with him twice both times the streering stuffed up . the truck ended up toe in at lest 15 dec he fitted a reneforcing plate to the passenger side idler arm but bent again when we were in taupo and was not anything hard, in the driving side of things.
he runs the same tyres as i do , but the saf goes better than it does
- mud_slinger
my mate has 1 he has had no real issues wit it couple months ago we dropped body on the drive and put chassis in garage wer we replaced every bush wit nolathanes and new shocks and suspension lift. hes runnin 31's. pretty reliabe. was sittin in garage for close 3 months put body back on and engine started 1st turn. good strong reliable nissan
needs more curry
0272593533
0272593533
Trouble is, the V6 guzzles fuel, and the TD is gutless. It is a nice wagon to drive though. Like what has already been said - 4k5 is a bit steep considering the age of it.
I would not buy a terrano again (I have a '94 TD), I'd go for a 3.0 diesel surf if possible - similar size, far more grunt, and reasonable economy too, just a bit ugly compared to the terrano.
- mud_slinger
Problems we used to see was rust under the back seat (double skinned, get's moisyure in and rusts from the inside out. Bout a $3k fix to do properly), Tension rod bushes/arms/brackets on the front suspension slogged out and cracked exhaust manifolds/broken studs.
My suggestions if you buy it:
Replace the manifolds with a good set of extractors - more power, less fuel and don't warp and break.
Get the ride heights adjusted to factory height and full W/A, (if you don't plan on lifting it.) you'll be amazed at the handling difference.
Before buying it, get a panelbeater to check out the panels under the rear seat. One in Marlborough would drill a small hole, fill the area with fisholene, then weld up the hole. This would stop it from ever rusting out.
1989 LN61 Hilux Surf
K&N Filter
Skyline Intercooler
2.5" Exhaust from Turbo
K&N Filter
Skyline Intercooler
- deer_hunter
- Driver/Navigator
nissans r awsum
ive had a TD 2.7 terrano for 4 years n the only things i had to do was serviceing tires n 1 set front brak pads now have a mistral since april last year n so far 2 tires n front pads plus reg oil n filters ive uped the boost on mine n its not over powered but it will pull like a school boy lol
yes the v6 is a bit thirsty but mmmm it sounds good,drives effortlessly and all round a good truck.....rust can be an issue last floor i replaced was
$1000 total not $3000 and yes the exhuast manifolds can warp but thats not really a major if you get extractors im told
my terrano
We got one in December, its a '91 3 litre V6. Its peppy and with a really lovely growwwwl. Pulls like a mule too. I love it. We test drove about 3 later model (93 & 94) TD's and they were utterly gutless. I wouldn't trust them for passing they had no pep at all. Also tried a couple of TD Surfs and they were the same - big lumbering things. Terrano petrol won hands down.
It is thirsty - put it this way, we dont just pop to the shops for a pint of milk now - but for $2900 it was a very good deal. $4500? Way too high.
Gay
Gay
u think
They mite be down on power but u cant beat the smooth pulling power of the TD2.7 and it takes sweet dam all to get them pulling better oh almost forgot can you get over 850k to a tank of fuel ? i can with my TD2.7
Re: u think
long wrote:oh almost forgot can you get over 850k to a tank of fuel ? i can with my TD2.7
heh, nowhere near unfortunately. On the positive side, I guess it means our cycles have got more use, and we've lost a few kgs since we got the Terrano
