Wtd td42 vacuum pump
frank
Stropper
Post by frank »
Hi guys does anybody have a good condition vacuum pump to suit a td42 24v forsale relatively cheap?
mudtroll
Re: Wtd td42 vacuum pump
Post by mudtroll »
I've got some lying around, coarse or fine spline?
frank
Stropper
Post by frank »
Thanks mate, Is it possible to find out what I have without removing it?
mudtroll
Post by mudtroll »
No, you'd have to remove it.
frank
Stropper
Post by frank »
Ok thanks, is there anything I need to know before removing it?
mudtroll
Post by mudtroll »
Whats wrong with yours? Theirs not a lot in them to go wrong.
frank
Stropper
Post by frank »
It apears the pump is warn out and is not producing enough vacuum, when first starting the truck it takes about 10 seconds for the light to go out then when applying the brakes after the second pump of the pedal it uses what vacuum has built up, it's been slowly getting worse but after a big weekend in the mud it's much worse
