40 series diffs
Pj_Marsh
40 series diffs
Post by Pj_Marsh »
What's out there? I'm after a rear diff, preferably braked and the mounts for a sway bar
Pj_Marsh
Re: 40 series diffs
Post by Pj_Marsh »
Still looking, or if anyone has any sort of a rear handbrake set up for an fj40/45
mudlva
Re: 40 series diffs
Post by mudlva »
Pj_Marsh wrote:Still looking, or if anyone has any sort of a rear handbrake set up for an fj40/45
Thought about using a 70 diff and moving the spring purchases to suit the 40.
Same width and already setup with hand brake etc
Pj_Marsh
Re: 40 series diffs
Post by Pj_Marsh »
I've got a coach built compartment on the rear of my truck which really limits the diff housing length, I can't go any wider without cutting the guards. Bit of a pain, closest ive got so far is checking out a 4 bolt full floater off an older fj45 that I can swap 70 series backing plates onto. At the moment mine is an 8 bolt so the backing plates wont match up.
mudlva
Re: 40 series diffs
Post by mudlva »
40 and 70 diffs are the same width just different spacing's for the springs.
cut the spring mounts off and reweld to suit the 40
40 stuff is getting harder to find now
Pj_Marsh
Re: 40 series diffs
Post by Pj_Marsh »
I've spotted a cheapish 70 series rear on trademe, one thing im not sure of is if my locker will drop into it. Anyone know if the rear diff head is the same size? This ones an '85 bj70.
mudlva
Re: 40 series diffs
Post by mudlva »
Just a thought
Beware that the coil spring 70 axles are out of prado and ran the 8" diffs.
The leaf spring axles are what you are after.
Yes the diff heads are interchangeable
Pj_Marsh
Re: 40 series diffs
Post by Pj_Marsh »
Cheers mud
