Work shop day (about time)
Hmm I was wondering if anyone would be intrested in knowing that on sat the 10th of feb my kids and handbrake will be overseas and i will have nothing better to do then sit in my work shop alone all day. Yes a work shop day if you want to fix your truck talk crap or weld stuff come along. Some idea of numbers and what you want to do will help. plenty of steel at cost price. So if your keen let me know
Woohoo... I've been waiting for you to say that! I want to make up some rock sliders to protect the sills and allow me to take off the running boards before they get too damaged. I probably won't have time to fabricate them as well, but if I can get the steel, get it cut and prepare a plan then at least I can weld it up at home later. Actually, perhaps I should just go hard on the day and get them done so that they can come in handy at Redwoods the next day....
Has anyone get some pics of a good design/setup somewhere so that I can start planning how to do it? Preferably on another whale?
gomulletgo
Hi Mark,
I've got a LWB patrol, just started making up some step/sliders - screwed up already, but that'll get sorted... just need to move the radius arms:). anyway, I've gathered / stolen about 10MB of piccies, plans etc - mainly from outer limits. Can email them to you if you want - just send me an address. I should have made sense of my mountings by the time the workshop day rolls around - will try and get some pics up if so. It's the mounts that are "interesting", then it's just a case of welding on some pipe, 100x50, or whatever you fancy. I got some 3mm steel bent to profile (100x50 with a corner cut off) , as I want to use as air tanks and I'm still having fun trying to figure out my welder, so don't mind the pixxing about. Mounting is a lot easier if you've got some body lift - gives you room for bolts etc.
cheers,
Terry
cheers,
Terry
- mroffroader
I will definetly be there and i will be doing my roll cage
.......will have hopefully done my new rock sliders by then
got my tube and plate today so all i have to do is design/cut all the steel out and then pinch red_zuki and or his welder so i can weld it all up and then thats the rock sliders done
then its roll cage time
80 series tow bus towing a redneck ass vitara
- mroffroader
- mroffroader
jumper wrote:mro what tube are you using for the roll cage and where did you get it![]()
stinky is it ok if i come down and bend a roll bar for the fj40 and lend a hand
i went down to steel and tube and bought about a 50mm diameter 3mm thick 6.5m long length of steel for i think $56 inc. GST and got some plate out of the scrap bin for the bottom plates
- mroffroader
- mroffroader
WACKO wrote:Ryan wrote:stinky wrote:Hi Ryan are we good to go?
yeah marty.....
you shud pm me dont wana advertise too much at
this stage......
hahah.. looks to me like you two have somthing cooking and your baiting the rest of us...![]()
i rekon aye and i tried to get some info from both of them and they wont tell me lol
