seasons greetings all...
over the new years going has slowed slightly but my interest has definitely not faded
h20 with his infinite wealth of connections was able to hook me up with a profile cut spacer.. 12mm deep, shaped like the top of the king pins and drilled to suit the soon to be placed hi tensile bolts..
took a stud out and placed all the lower arm, cone washers,spacer, upper arm and its cone washers on to measure the length of bolt needed... i'm goin shoppin for four 80mm by 12mm thread grade 8.8 nickel bolts tomorrow..
mocked bits to measure length of bolt needed.. (p.s, i know, top of flipped king pin is ugly... that'll be goin too..)
lined up the steerin box to approximately where its going to be livin out the rest of its life.. putting 5mm on both sides of chassis rail and bolt right through with the crush tube sittin between the plates etc...
mocked mounting..
will be more to come on this..
keep cool till after school..
