Got Some More Optima Batteries
Moderator: Vendors
4wdstuff
Postby 4wdstuff » Thu Sep 17, 2015 9:00 pm
Hi,
As the title says I have got some more batteries as per below.
Optima 8004-003 Red Top Starting AGM Battery 34/78 CCA 800 amps Can do these for $350 plus post.
Optima 8012-021 Yellow Top Deep Cycle & Starting AGM Battery D34, CCA 750 amps. Can do these for $425 plus post.
Optima 8012-045 Yellow Top Deep Cycle & Starting AGM Battery D34/78, CCA 750 amps. Can do these for $435 plus post.
Optima 8051-160 YellowTop Deep Cycle & Starting AGM Battery D31A, CCA 900 amps. Can do these for $525 plus post
Post to Auck $10, Lower Nth Is $15 and Sth Is $25.
If interested send me an email on 4wdstufftim@gmail.com
Tim
4wdstuff
Re: Got Some More Optima Batteries
Postby 4wdstuff » Sun Sep 20, 2015 11:05 pm
Bump
mike
Last minute Mike
Postby mike » Mon Sep 21, 2015 10:14 am
I've had optima batteries for ten years in my truck now, the same ones. Multiple times flat (both of them, usual story, lights on slow drain oops), used in anger for long winches, winch comps etc. Both going strong but obviously not as good as when I got them but still pretty bloody awesome. It would take a bit of persuasion for me to go to something else :mrgreen: Just thought I would put that out there if you thought the price of these things are expensive. Over ten years it works out bloody cheap!
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
fh2014
Postby fh2014 » Mon Sep 21, 2015 1:03 pm
what one would you recommend for a 2.7td terrano with the usual accessories, 9500 winch and spot lights?
4wdstuff
Postby 4wdstuff » Mon Sep 21, 2015 8:07 pm
Yellow top if using a winch, red is more just for starting with light electrical loads.
Bigger the better if it will fit. If doing alot of winching 2 is even better.
Only difference between the D34 and D34/78 is the D34/78 has a couple of extra terminals on the side for connecting to.
Tim
4wdstuff
Postby 4wdstuff » Fri Sep 25, 2015 1:59 pm
Bump
Tim
4wdstuff
Postby 4wdstuff » Tue Oct 13, 2015 12:39 pm
Bump
Tim
BlakeNZ
Postby BlakeNZ » Thu Oct 29, 2015 7:31 pm
wow, these are really sharp prices.
4wdstuff
Postby 4wdstuff » Mon Nov 16, 2015 4:51 pm
4wdstuff
Postby 4wdstuff » Fri Apr 08, 2016 11:07 am
Bump
Tim
Big
Postby Big » Wed Apr 13, 2016 5:15 pm
finally looking at another one Tim.. got any deals going ? big is better :lol: :mrgreen:
4wdstuff
Postby 4wdstuff » Wed Apr 13, 2016 9:56 pm
Hi Keri,
Sold out of the big ones at the moment, getting some more in next shipment.
Will send you a PM
Tim
4wdstuff
Postby 4wdstuff » Sat Jul 30, 2016 10:16 pm
MihiT
Postby MihiT » Sun Jul 31, 2016 6:53 am
Any blueys? I think it was M34 I was looking at
4wdstuff
Postby 4wdstuff » Sun Jul 31, 2016 10:51 am
Sorry only Yellows, any particular reason you want Blues
Tim
Crawlerer79
Postby Crawlerer79 » Sat Aug 13, 2016 6:59 pm
Hi Tim,
When will the Red Top batteries be back in stock.
It's nearly time for my Landies battery to be replaced :roll:
Tim
'Lando' - 1994 V8 Disco
Return to “Winches, Accessories, Tools and Supplies”
Users browsing this forum: No registered users and 24 guests
