Just a couple of quick questions....
1) Can you cut/trim front and rear guards on a monocoque chassis 4x4 without requiring a cert?
2) Do you have to weld the inner and outer skins back together or can you safely use an automotive sealer?
Thanks in advance,
JP
Monocoque chassis and guard trimming
Re: Monocoque chassis and guard trimming
Just heard back from the Cert guy - this is structural so needs to be cert'ed, but only for the rear guards. The fronts are bolt on so he is happy for me to cut about 50mm.
good update there. that will be useful for people in the future , I'm sure.
PS post a "Build" thread please...
I'll see what I can do. I like to build, not take photos haha.BlakeNZ wrote:good update there. that will be useful for people in the future , I'm sure.
WJ Grand Cherokee will be getting a 4" lift and 285/70R17s fitted. Also adding adjustable upper and lower front control arms and an adjustable track bar/panhard rod. Will definitely have to trim the front and rear bumpers but since I'm going for a cert I may as well weld some rock sliders on and cut the guards at the same time.
v8 tj...luvs the gas......
