Madaz's V8 lux
turoa
Pyro Junior
Post by turoa »
Heres some shots of the fabrication thats gone into the transmission tunnels.
Looks like alot of work :?
And a Video
mroffroader
Post by mroffroader »
hell yea!!! :!: :twisted:
Madaz
Post by Madaz »
It isnt a 5 minute job getting a landcruiser transfer case under a hilux body without a body lift, I couldnt even guess how many boxes of beer were needed to get the floor back in and the seats back at the right height. :roll:
Wouldnt do it again in a hurry :twisted:
swampa
Post by swampa »
no body lift, good on ya, same with mine, everything would be so much easier with a 2 inch body lift, but as low as possible is my motto with the biggest tyres, what coil set up you using?
Madaz
Post by Madaz »
Yeah 2inches would have helped, but 4 inches would have been better.
Cutting out the floor was the best fix and avoided some other issues which might have stopped it getting certified , but it was a prick of a thing to get it right.
Suspension is a bit of mix and match using bits of: jeep, terrano, safari, landcruiser and pajero. :oops:
Hope it all works
swampa
Post by swampa »
from the pics is it a 3 link on the front and a 3 link or 5 link in the rear, also what steering box are you using?
Madaz
Post by Madaz »
3 link front and rear-simple and strong
Cruiser power steer box cause the hilux was actually a beam axle 4runner with arm strong steering.
Got any pis of your rig swampa?
Mattman
Post by Mattman »
I would be interested in the elocker and a pair of 8in 4.88 heads. What ratio does the locker have?
I am also trying to locate a Prado coil front solid axle with arms etc.
Matt.
wjw
Post by wjw »
Madaz wrote:How much of a premium, cause I've got a couple of sets in the garage
1 set of 4.8s ,1 set of 4.3s and 1 set of 4.8 out of a prado( turoas keen on these)
Also have a toyota e-locker that might be surplus to requirements( to fit a 8 inch head)
hmmmmm
Who knew Prados could fly?
turoa
Pyro Junior
Post by turoa »
Ill let madaz explain this one :wink:
lilpigzuk
Tiger Balm
Post by lilpigzuk »
ya hilux needs a brazilian.....
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Mattman wrote:I am also trying to locate a Prado coil front solid axle with arms etc.
Matt.
http://www.trademe.co.nz/Trade-Me-Motor ... 411373.htm
Madaz
Post by Madaz »
Sweet as LPZ :lol: :lol:
Its not some kind of inner growth on the inside of the guard , but the bottom of the airbox that we layed up in there.
Not really that happy with the fit of any of the other air cleaners I tried so I'm just gonna make something and see how it works out.
TeLexs
Post by TeLexs »
Madaz wrote:It isnt a 5 minute job getting a landcruiser transfer case under a hilux body without a body lift, I couldnt even guess how many boxes of beer were needed to get the floor back in and the seats back at the right height. :roll:
I went for the 2 inch body lift and it went streight in also keeped with the prado 5 speed . Very nice job mate are you going to put it in the winch comps , should go well , nice length , good winch , got to go well , mines a D/Cab 1uz blowen , with mid mounted winch (pto and elec)sitting on nissan diffs and coils , still working out how to drive it . look forward to seeing it on the road . Cheers TeLexs
Madaz
Post by Madaz »
Cheers for that TeLexs
I ve seen you truck at the last 2 winch comps, awesome horsepower!
How much grunt are you getting out of it now?
Hope to be racing it later this year , finances permitting
TeLexs
Post by TeLexs »
1UZ Has been going strong with that blower till" now ", Started to use a lot of water and was running very hot so have just pulled it out of hilux and striped it down . She has a blowen head gasket and needs new pistons / liners / rings / havent got to the bearings yet , 10 lbs is a bit much for the piston lands to handle and over driving the blower heats up the air to much so will now fit the inter cooler and decompress the pistons . TeLexs
Rangielux
Post by Rangielux »
Will be good to see you guys (madaz & TeLexs) going head to head one day, might even have to have a wager on it :wink:
when I'm not too busy (in the winter and when it's nice and slippery) and Madaz is up and running I could set up a couple of practice stages out at Ngaroma for yous to practice on if you're keen.
TeLexs
Post by TeLexs »
Rangielux wrote:Will be good to see you guys (madaz & TeLexs) going head to head one day, might even have to have a wager on it :wink:
Wager sounds good . How about at the next Rerewhakaaitu run , Scott's. talking about running another school fundraser , winner could give the winnings to the school if he or she wonted too. This time he is going to make it tougher than last year so get your trucks ready. Rangielux this time you can have another go at hugging that tree :lol: :lol: again , That was one of the funniest things ive seen 4wding , chainsaws are a lot easer on you gear mate :lol: :lol: .. Will keep every one posted on dates . Cheers Klem
Madaz
Post by Madaz »
What month is this run your talking about, and where is that near?
Rangielux
Post by Rangielux »
TeLexs wrote:Rerewhakaaitu run , Rangielux this time you can have another go at hugging that tree :lol: :lol: again , That was one of the funniest things ive seen 4wding , chainsaws are a lot easer on you gear mate :lol: :lol: .. Will keep every one posted on dates . Cheers Klem
:scratch: Silly place to plant a tree or a silly place for a track, one or the other :lol:
Over by Rotorua near Rainbow mountain ish, was mid-winter last year Madaz. I got to fix my truck first - broke both engine mount rubbers and one trans mount going silly (lucky it's also chained in) other wise it could've fallen out the bottom :oops:
turoa
Pyro Junior
Post by turoa »
Heres some new pics :wink:
[/img]
Mattman
Post by Mattman »
Looking good Tim.
Matt.
monaro427
Post by monaro427 »
looks like it would be a sweet lux, who did the fab on the inner rear guards, all the the panel work,
Rangielux
Post by Rangielux »
Looks like Madaz's workshop has the same energy source as the monster garage in Taupo! (Steinlager :D )
TeLexs
Post by TeLexs »
I think its better than V . Looking good the PROJECT . Get some good ideas up north at the winch comp , We came back with more parts , Chassis (hilux) Nissan diffs , I fell another monster build just around the corner :twisted: :twisted:
shortylux
Post by shortylux »
If you spent less time on here Madaz, then maybe you'd have the truck going by now. Maybe.
Madaz
Post by Madaz »
All I hear is BLAH BLAH BLAH |-)
Wheres your truck?
(Did my missus put you up to this?)
shortylux
Post by shortylux »
Mines still in the garage cause I spend to much time on here. Might have a rollcage by the end of easter though. Probably not.
Madaz
Re: Madaz's V8 lux
Post by Madaz »
Got some new pics to show that it hasnt died.....
wopass
Re: Madaz's V8 lux
Post by wopass »
when are you going to bring it out for a skid mate ?
