At about the end of August last year I got a 1987 model SJ413 Samurai.
What its got :-
Standard 1.3 N/A engine
30in Dunlops
16 inch steel rims
As I have only just turned 16
Its not really mine but I call it that
So far I have : -
Changed oil & oil filter
Reset leafs
New water pump
Reconditioned the radiator
(I know that some of these things are maintanence but all the same
So after getting more and more depressed with its condition sitting in the drive after a few outings I drove it into the garage and got to with a bit of work on it.
We got it off a guy at work that had gotten it for free but it just ended up sitting on his land doing nothing. A tree fell on it so there are a few dents and for some unbeknown reason the rust on the right side is worse than the left, but anyway.
Most of the rust is along the roof line and in the right wheel arch.
So here are a few pics of the rust before and after.
As you can only attach 5 pics at a time Ill put some more up in another post.
And a bit more reading for you all.
