Hey fellas has anyone experienced a jumpy tachometer needle?
Its in my rodeo wich is an isuzu really, it goes up when i turn to the left and down when i turn right, so its affected by gravity somehow and most of the time sits about 2.5 regardless of actual rpm, its annoying me!
jumpy tach
Re: jumpy tach
Sounds like the cable is loose
Re: jumpy tach
i had a poke around but couldnt figure out where the sensor is,
Re: jumpy tach
Want to swap ? mine is 500 rpm for engine tuning aND 1500 when I toot the horn . Ha ha
Electronic in a ln106 tho
Re: jumpy tach
Unless there's a known solution for the vehicle, my general advice would be to pull the cluster and re-solder all the connections on the daughterboard. Check for wires around the steering column that are pulling, pinching or rubbing.
- skid
- Tyre Man
Re: jumpy tach
my 80 series used to do that as well, then one day it just stopped working
speedo cable had snapped
Re: jumpy tach
The tacho was jumpy coz the speedo cable snapped ??
Re: jumpy tach
MihiT wrote:Unless there's a known solution for the vehicle, my general advice would be to pull the cluster and re-solder all the connections on the daughterboard. Check for wires around the steering column that are pulling, pinching or rubbing.
That is how if fixed faulty tachs in my pajero and hilux
Users browsing this forum: No registered users and 2 guests
