96 v6 surf
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
old pan off
look how clogged the old filter is
and how clean the new one is
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
new pan on.
new dipstick.
Andrew 0272226292.
Mattman
Re: 96 v6 surf
Post by Mattman »
Nice work
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
rear driveshaft hoop done. 50x5mm flat & 4x 10mm 8.8 bolts so hopefully pass cert.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
front bar made.
thanks baden.
next job bar off, paint it. next weekend swap rear diff for the prado diff & 4" lifted springs. bleed brakes. then fit (hopefully can figure it out) the TRD supercharger etc.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
1st coat of paint tonight.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
surf rear diff out.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
and prado diff in.
put power onto locker to unlock it, jacked a wheel up and can spin one.
brakes bled, enough to get it to town anyway.
tonight's jobs are put another coat of paint onto front bar, & trim shroud because fan blades are hitting it, new viscous hub is a bit longer than the old one.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
fitting the supercharger.
before
during
now just need the done photo.
still some vac hoses to hook up, and one wire left on the computer and hopefully will be going. :mrgreen: 8)
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
supercharger on, hoses hooked up. can't try it cos it won't start.
130 windscreen washer in, 185 one was where the steering box is now.
bar on, lights fitted apart from indicators. winch in but rope not on yet. bash plate will go on when I have made some 90 degree bends for the trans cooler hoses. still need to swap hubs to surf ones, will be a bit wider then to match rear.
Andrew 0272226292.
Mehrts
Re: 96 v6 surf
Post by Mehrts »
That's a pretty neat fit with the supercharger with regards to manifolds etc, nice and compact
Toyhatsu Bitsalux
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
Mehrts wrote:That's a pretty neat fit with the supercharger with regards to manifolds etc, nice and compact
TRD, so just bolts into place. vacuum hoses are different lengths but otherwise straight swap.
Andrew 0272226292.
OffroaderGuy
Re: 96 v6 surf
Post by OffroaderGuy »
good progress. impressive work
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
OffroaderGuy wrote:good progress. impressive work
Mattman wrote:Nice work
cheers.
front hubs are done, front wheels are in about 10mm each side compared to rear, so will get a fresh bite on side of rut.
photos to come....
is now running, ended up being a plug unplugged behind dash :oops: :roll: but still vacuum to sort.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
been slow with moving house and job.
but got something done.
removed intake silencers, americans reckon a gain of 5-7RWHP so must do something, :) and supposed to sound gruntier too. :D
hopefully let the supercharger breath a little bit easier. 8)
removed these.
next job wire supercharger computer back in.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
Sc computer wired :lol: :roll: in, haven't started it yet.
Auto sparkies close eyes now....
And a bit tidier.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
back nearly stripped out ready for cutting. roof lining to unclip and windows to take out.
seats can stay there until back is in right place then take them out.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
no going back now. :)
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
Now just got to measure where it's going to fit and cut it neater. seat belts dictate where back goes.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
A bit done, partly bird pood in. A few gaps where not cut flush, will cut guards and pull gaps closed, won't be visible behind deck anyway.
Think I might buy a regulator and disposable bottle for the panel work.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
Big achievement for the weekend, made an extension for handbrake cable holder thingy :lol:
Worked half of Saturday dagging last of ewes ready for shearing, and only got an hour in shed.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
Got sick of spot welding panel steel so started on rear cross member.
Andrew 0272226292.
catalystracing
Re: 96 v6 surf
Post by catalystracing »
Good looking project Andrew, did the steering wheel fit like you hoped ?
Was good to meet you and the family Saturday, hope the trip home went well.
Paul.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
catalystracing wrote:Good looking project Andrew, did the steering wheel fit like you hoped ?Was good to meet you and the family Saturday, hope the trip home went well.Paul.
haven't tried the steering wheel yet, hopefully will fit.
good to meet you, and put a face to the name. got home about 6.
Andrew 0272226292.
sirLachlan
Re: 96 v6 surf
Post by sirLachlan »
I'm pretty sure that drive shaft hoop will require another piece in the middle to encapsulate the drive shaft more . If it broke and traveled the length of the u bend it would have no trouble whipping all that off
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
sirLachlan wrote:I'm pretty sure that drive shaft hoop will require another piece in the middle to encapsulate the drive shaft more .
I have wondered if that would be the case, so will end up making another piece to bolt in centre closer to the driveshaft. another job added to the list.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
All closed in, just some bog to smooth off and paint. :D quite pleased considering it's the first time i've used a mig.
Andrew 0272226292.
BlakeNZ
Re: 96 v6 surf
Post by BlakeNZ »
awesome, been waiting for this stage. Any side on photos?
Can i assume you are retaining the rear window function of being able to be wound down, electrically?
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
BlakeNZ wrote:Can i assume you are retaining the rear window function of being able to be wound down, electrically?
that was the plan, but would only go down to top of arches, which is about half way. also I had to cut the bottom off the runners the window slides in to fit around arches. so window now doesn't move.
plus the rear radiator will either be behind window on the left, or horizontal on roof straight above rear window so be safer if window didn't open anyway.
BlakeNZ wrote:Any side on photos?
have tried to take a sideish on photo but not much room in shed, i'll add off my phone.
Andrew 0272226292.
mudsurfv6
Re: 96 v6 surf
Post by mudsurfv6 »
Andrew 0272226292.
