anticorrosive primer?
icekayak
Post by icekayak »
Ok i'm working on a body that has a bit of rust through it, and cut out all the rust i can see and will weld patches in, but want to spray something inside all the panels etc to stop any rust that hasn't broken through and to protect it further...
can anyone recommend a cheap anti-corrosive/primer/rust killer/thing?
chris
MudBum
Post by MudBum »
Hi Chris,
1st- Get some Black Guard Rust Kill and make up some way of spraying/coating the inside panels and leave overnite, this leaves a converted metal surface with primer like coating.
You could then (if able)to spray any type of paint over that just for insurance and follow up with some Cavity wax or Fisholene once the paint has dried.
All of these products you should be able to get at your local Panelbeater supplies outfit.
Or for the BEST results if you can spray in side the panels is to use a Resene Automotive product called Durepox. This is a 2pak Epoxy that is waterproof when cured,not dear to buy but application with a spray mask essential. 8)
***Prior Preparation Prevents Piss Poor Performance***
Most sports require only one ball - real sports require two.
Ryan
Post by Ryan »
a product call POR15 is excellent for that its a u-pol product
or a red oxide primer like PA-10...
once primed and painted dont forget to get some caverty wax of some kind and spray that inside too
hope this helps
Bubba
Post by Bubba »
What’s caverty wax? Yeah yeah I know it's wax you spray into the cavity, thought I would get in before you flex your sarcasm muscle :wink:
Return to “Tool Shed”
