Name the broken bit
wjw
Name the broken bit
Post by wjw »
What did I break?
Who knew Prados could fly?
BlakeNZ
Re: Name the broken bit
Post by BlakeNZ »
Harder to guess with no size reference- spider gears on a diff maybe? There appears to be a HEAP of wear on the shaft thing(technical term)...
imsohi
Post by imsohi »
Landcruiser 80 centre diff
Lchundy
Post by Lchundy »
Far out how you do that
Been practicing your quater mile launches or driving round with cdl on?
Crash bandicoot
Post by Crash bandicoot »
Expensive is what part it is :mrgreen:
wjw
Post by wjw »
I reckon it's engine braking that's caused it to finally go. Having changed to a manual gearbox, my guess is that is now the weakest link.
tweake
Post by tweake »
i would take a guess that its the welding thats weakened it. but the severely worn cross pin shows it was pretty stuffed before the welding. looks like you got your money out of it, time for a locker.
suzolla
Post by suzolla »
Did that have a part time mod, was it welded ?
imsohi
Post by imsohi »
suzolla wrote:Did that have a part time mod, was it welded ?
Looks like it to me
wjw
Post by wjw »
Looks like it to me
Yea that was the "cheap" part time mod :-) Have done the same again using parts from a spare case.... but
I have ordered one of these:
hamishh
Post by hamishh »
Just curious but what is the cheap part time mod
keithal
Post by keithal »
hamishh wrote:Just curious but what is the cheap part time mod
i would assume by welding the spiders connected to the rear output on the center diff driving the rear end leaving the front unattached till the center diff lock and hubs are engaged?? just guessing tho
wjw
Post by wjw »
Return to “Tool Shed”
