Righto chaps, may have a plan to fit a pto onto my surf, but looking for a landcruiser pto and the auto to surf transfer case adapter to see weather my plan is feasible
Prefer around the Waikato as big bulky items to ship but not essential. Also doesn't have to be in working condition if cheap
Cheers Alistair
Landcruiser pto and surf auto to transfer adapter
Re: Landcruiser pto and surf auto to transfer adapter
In the Landcruiser the pto takeoff is in the transfercase....
I have heard thru the grapevine that there is a surf / hilux transfercase which sports a pto but it was just a whisper...
Never seen one in the flesh.
Not wanting to go down the track of landcruiser transfer case just yet, as offset rear driveshaft)yes I know people have successfully done this in the past)
Am thinking about cutting and welding a flange in the adapter between auto and transfer (mine is chain drive) and putting a drive gear in the collar that drives from auto to transfer.
Will it work? I'm not sure.Also not sure if it would put too much side load on the bearings as not designed for
I like your thinking......
I know with my Prado setup there is plenty of shaft between the two in the adaptor part....... (auto)
Will watch this thread and see how yah go...
Will be a slow project when I can find parts.but will post up if it's successfulkbushnz wrote:I like your thinking......
- Bush Crasher
Iv got a compleat 70 series pto set up if your still looking
Depends what your after for it all?davemeasures wrote:Iv got a compleat 70 series pto set up if your still looking
- Bush Crasher
Say 500 winch has 30 mtrs of cable could be more just needs free spool freeing up
