We all no what that means right.............
Its got about 220,000ks on it, so its getting to about the right age for it to happen, and I have been watching it closely looking for signs.
I do 120k's a day in it to work and back, and everyday for the last few weeks, the level in the overflow tank has been dropping down about 10mm below the line on the tank. I fill it up in the morning to the line on the tank, do the commute, then check and fill the next morning.
What's unusual is that the radiator level is always good, so its drawing back from the tank as it cools. Its also not pushing excessive amounts of coolant out into the tank, it looks just like the normal amount you get from expansion.
There is no white steam on start up. It starts first flick and idles smoothly.
Oil is clear, no bubbles in the coolant when cold. When hot, its all circulating pretty furiously in the top tank with the cap off, maybe circulating to much, it is a bit messy, and very hard to see bubbles. Yet, its not chucking water out into the tank......
I have been round and round the engine bay looking for coolant leaks from hoses, radiator, tanks etc. Cant find anything. Its much more like a coolant leak from a hose or radiator, except that with that sort of leak, you generally loose coolant from the radiator and the expansion tank stays steady.
Its got to be the head right?? Just the early signs of it, with out the bubbles in the coolant, throwing water out into the expansion tank, white steam from the exhaust and rough idle on cold start
Any tips or tricks on diagnosis??
And any advice on sourcing a head, bolts and fitting
Pete
