prado/surf SAS 4" lift custom radius arms
brakes-shocks-lockers-etc
mudsurfv6
Post by mudsurfv6 »
has anyone or know of anyone who has made their own radius arms? how did it work out?
there are a few that can be bought but aren't cheap.
can't be too hard for a competent engineer can it? need to be certifiable.
Andrew 0272226292.
Lchundy
Re: prado/surf SAS 4" lift custom radius arms
Post by Lchundy »
Do you want your truck road legal? have a talk to your certifier about it first.
I was thinking about custom arms when building my truck but certified wasn't really keen on the idea
mudsurfv6
Post by mudsurfv6 »
Lchundy wrote:Do you want your truck road legal?
yes that's the plan.
Lchundy wrote:have a talk to your certifier about it first.
might have to, been on LVVTA forum asking but been nearly a year and still no answer. :|
Andrew 0272226292.
wjw
Post by wjw »
mudsurfv6 wrote:might have to, been on LVVTA forum asking but been nearly a year and still no answer. :|
Phone them :-) I got an answer straight away when I callled about my gearbox. As it's logged in their system they even give you a reference number in case anyone queries it.
Who knew Prados could fly?
mudsurfv6
Post by mudsurfv6 »
they said replacement arms have to be same strength or stronger than originals, and preferably longer.
also asked about reshaping the brackets that the factory arms bolt into to keep castor right if I keep using them and they happy.
something like that.
Andrew 0272226292.
keithal
Post by keithal »
mudsurfv6 wrote:they said replacement arms have to be same strength or stronger than originals, and preferably longer.
if your going to the effort of custom arms wouldn't it make more sense to incorporate the castor into them than change diff brackets?
mudsurfv6
Post by mudsurfv6 »
keithal wrote:if your going to the effort of custom arms wouldn't it make more sense to incorporate the castor into them than change diff brackets?
yes, sorry obviously I wasn't very clear. if I go custom arms then that's what I would do. if I stick with the prado arms then I would change the brackets on diff.
just need to figure out which its going to be.
Andrew 0272226292.
Clint
Post by Clint »
You probably can't angle the arms up very far on the diff like that without them hitting the steering tie rod that sits above them. You can see the custom arms in the pics above have a big kink there to clear the tie rod.
Clint
UZJ71 Landcruiser
KTM 640
mudsurfv6
Post by mudsurfv6 »
Clint wrote:You probably can't angle the arms up very far on the diff like that without them hitting the steering tie rod that sits above them
tie rod is in front of the diff.
Andrew 0272226292.
Clint
Post by Clint »
No worries then :D My LJ71 had it behind but hilux/surf must have it in front? In that case you'd probably be better off making your own vs aftermarket lift prado arms as you could make them without the kink & they'd be stronger.
Clint
UZJ71 Landcruiser
KTM 640
mudsurfv6
Post by mudsurfv6 »
Clint wrote:No worries then My LJ71 had it behind but hilux/surf must have it in front
yeah heaps of room.
surf do up to 1995 (ifs), beam axle were only made 1984-86, and hilux to 1997 then its steering rack behind diff. (someone say if I'm wrong).
but mine has prado/hilux diff, 80 series LC steering box and 70 series LC tie rod and drag link.
Andrew 0272226292.
Lchundy
Post by Lchundy »
When I was searching internet for ideas for radius arms on my wagon I did find a 80 series that had factory radius arms mounted upside down to the top of the diff,but that idea was to clear steering arms
They way it was set up gave it good caster and it ended up moving diff forward slightly
I ended up using aftermarket bolt in arms so didn't really look that far into it but might be worth seeing if it will work for you
mudsurfv6
Post by mudsurfv6 »
went and had a look after reading ^^ and looked at drivers side and thought it might work but looked at passengers side and maybe not. the panhard might be in the way when the left wheel goes up, depends on how high the arm sticks up, but will look into it.
Andrew 0272226292.
Sausager
Post by Sausager »
I don't see why these would be hard at all. Do they have to be one piece, or can they be fabricated?
mudsurfv6
Post by mudsurfv6 »
Sausager wrote:Do they have to be one piece, or can they be fabricated?
all LVVTA have said is 'they must be as strong or stronger than current arms' so whatever is going to work. some of the manufacturers of these arms say one piece is stronger and welding is weak but they probably just want to sell theirs.
Andrew 0272226292.
Clint
Post by Clint »
The way I'd do it would be to design them to suit your build exactly, machine up the diff end bush housings (or hack them out of some old suspension links if you can find some the right size) get the arm profile cut from 30mm plate with holes to weld your bush mounts into.
The chassis end is where it gets tricky as there are cool super flexy, tough & rebuildable joints you can get that would be ideal but you're not allowed greaseable for cert & I think most of them are. So you could just go with another rubber bush (80 series style NOT GQ pin style) or drill & tap for a big rod end like the 25mm SKF ones I adapted on to my Nissan arms but a male thread. Maybe weld plates either side of the hole to strengthen the thin bit.
Clint
UZJ71 Landcruiser
KTM 640
Lchundy
Post by Lchundy »
I wonder if the stock 80 series radius arms are longer than the prado ones
I've looked under a prado and the 80 series arms look more stronger built
Could be a cheap option.
mudsurfv6
Post by mudsurfv6 »
Lchundy wrote:I wonder if the stock 80 series radius arms are longer than the prado ones, could be a cheap option.
I'm not 'too' worried about the length, though a bit more would be good. its the angle they rise away from the diff end, keep standard angle at diff but lift chassis end up.
do you know if 80 same shape/angle as prado? are the mounting holes at diff the same as prado?
Clint wrote:The way I'd do it would be to design them to suit your build exactly, machine up the diff end bush housings, get the arm profile cut from 30mm plate with holes to weld your bush mounts into.
that looks like the plan.
Clint wrote:The chassis end is where it gets tricky, you could just go with another rubber bush (80 series style NOT GQ pin style)
I would imagine that would be the simpler rather than a rod end. its not set up for huge amounts of travel, that's for another vehicle sometime.....
Andrew 0272226292.
axel
Post by axel »
80 series radius arms are almost identical shape to prado 1s but definitely a stronger unit. I have a photo somewhere showing the 2 overlaid. From memory the 80's r about 5-10mm longer with a slightly steeper?? caster angle if used on prado mounts.
mudsurfv6
Post by mudsurfv6 »
I've got prado diff but custom mounts at other end which need to go up about 150mm, without measuring it.
Andrew 0272226292.
